Centre Channel - Location Selection
  • Centre Channel - Location Selection
    I'm trying to make this as unobtrusive as possible and still get optimum centre channel staging. I'm considering 2 centre channel speakers on either side of the centre consol. Her's a what my centre consol looks like (pic is not mine specifically). I'm thinking that a 4" on either side should work well???
    http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
    1990 RHD JDM 300ZX TT 2+2 5sp T-Top
    491RWHP / 18psi / 94 octane
    What goes in that hole above the screen?
      HVAC
        without seeing a pic of the dash of your car it's next to impossible to give any suggestions.
        Jan Bennett
          Is the HVAC all electric or are there vacuum lines or cables? If it's all electric relocate it and get a wide dispersion horn for your center channel to put there
          You spelled center incorrectly
            Well he's canadian "eh" give him a break... Well then on second thought, go ahead...
            PROGRESS:
              HVAC is cable actuated and unfortunately can't be moved. Wide dispersion horn??? - I didn't think the freq range for one would go low enough to cover cent(er) channel freq range effectively.
                Most center channel stuff is human speech which is upper midbass and above. Horns have REALLY good response ranges but they're pretty freakin expensive.
                I was just messing with you about the spelling. Us yanks spell a lot of stuff differently.
                  grrr, centre, harbour..
                  doesnt matter, means same thing, haha
                  why do canadians/americans spell them differently anyway, never really understood that
                    Its going to be tough to get that out of 4"s in a free air environment. I wouldnt worry so much about frequency range on the center channel unless you are timber matching. A single decent quality 4" should do ok.
                    I'm using the center of my dash, pointing up, for my 6.5" center channel. It requires cutting out the center of the HVAC duct but that can be easily fixed with duct tape.
                    You could always grab a center channel speaker from home audio (a little enclosed number) and work it into the space between the windshield and dash. Keep it as far as you can forward. Play a bit with making a custom grill and some decent adhesive and you are good to go for a temporary solution. (Temporary until you switch your vehicle).
                    Most home speakers are 8 ohms so plan on double the power for your center channel when appropriate. you get the idea...
                    Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
                      center/centre, check/cheque .... psssst ..... French history may have something to do with it??
                      $$$$, hmmmm. I think I may have to continue to look at some small 4" full range speakers. I've only got about 1 .75" of depth to play with so I think my options are limited. I haven't started to look for specific speaker brands since it's been a while since I've had to do car speaker shopping (11 years - don't laugh either - previous install by me was so good, it's never hiccupped or failed in all of those years). I'm not to aware of current market quality speakers in this size area and will start with some familiar old names like Boston Acoustics, MB Quart, KEF, Audax and the like.
                        I hope these will help Jan. I'd use the grills that would come with the speakers of course. Something in the range of a 4" +/- speaker with a max depth of 1.75".
                          Install it in one of your upper vents. Do it behind the grill. Block it off and feed air to the other side.
                            I imagine that's an option too. I'd prefer not to though since it took me some time to source the 4 dash vents from an E-Spec 323F from Holland.
                              My speakers just came with packing foam, some crappy speaker wire, mounting hardware and grilles. No grill.
