Thinking of using focal power dual mono amps... how to do 5.1?
  • Thinking of using focal power dual mono amps... how to do 5.1?
    ... or should I not bother with surround sound?
    I'm building speak with me demo car number 2.
    Demo car number 1 is my daily driven g35, pics of that are here:
    http://weblogs.asp.net/ajuneja/default.aspx
    the g35 used the alpine pxa-h701, an alpine dva-9860 headunit, a mcIntosh main amp and a JL sub amp and a shuttle in the trunk, and a xenarc in dash screen.
    This next car will be using a much smaller computer... and I am thinking no extra signal processer, but just hook up the focal amps right to the computer.
    I think this would work... wanted to check with the crowd here if it would...
    www.speakwithme.com
    2004 Infiniti G35/Focal 165 K2P front stage /Focal 165CV rear/JL 10W6 sub/Shuttle PC in trunk/Alpine PXA-H701/Alpine DVA-9860.
    Got a link to the amps?
      from red's sticky:
      7. Focal FP Dual Monitor
      This is one bad *** amplifier.
      No prices yet.
      http://www.focal.tm.fr/car/en/index.htm
      Nominal power measured at 13.8V continuously @ 4 ohms: 2x300W RMS
      Nominal power measured at 13.8V continuously @ 2 ohms: 2x400W RMS
      Power in bridged mode measured at 13.8V continuously @ 4 ohms: 1x800W RMS
      Power in bridged mode measured at 13.8V continuously @ 2 ohms: 1x1200W RMS
      Power supplies Dual fully regulated
      Signal/noise ratio >110dB (A)
      Damping factor at 4 ohms >600
      Frequency response (-1dB) 10Hz-45Hz
      Input impedance 13kohms
      Input sensitivity 0.2-5V
      Digital inputs Coaxial/optical
      Output stages Triple Darligton
      Operational amplifiers Burr-Brown
      DSP 2 internal DSP
      180 mips each
      Converters 24-bit/96kHz
      Crystal®
      Software Provided
      Remote control Provided (gain+5 presets)
      Digital graphic EQ (each input channel)
      30 bands of 1/3 octave
      Digital delay line (each input and output channels)
      2 inputs and 2 outputs, 2048 samples max.
      Digital control From external PC via USB port
      High-pass crossover Slopes and frequencies fully adjustable
      Low-pass crossover Slopes and frequencies fully adjustable
      Digital parametric EQ 1 band fully adjustable
      Maximum cross section of loudspeaker cables 10mm = 7 AWG
      Maximum cross section of power cables 51mm = 0AWG
      Protections DC offset
      Short-circuit
      Continuous power
      Thermal overload
      Soft clipping
      Over voltage
      Polarity error
      Dimensions (HxWxD) 50x540x280mm (2x21.25x11“)
      Weight 7.5kg (16.53 lb)
      www.speakwithme.com
        you would be able to set it up like any other 5.1 system if I'm not mistaken.
        The amps are able to be linked and controlled directly VIA the PC.
        However, I personally don't see any purpose for 5.1 in a car. however, some people really want to try for it, more power to them.
        Jan Bennett
