How do you have your CarPC hooked up to your audio system?
  • How do you have your CarPC hooked up to your audio system?
    I'm sitting here reading through various posts and various web pages, and I'm noticing the different methods that people are using. it got me to thinking about how it might be nice to have a poll, just to get some ideas.
    So here goes!
    89
    From the onboard sound direct to aftermarket amps
    8.99%
    8
    From the onboard sound into the factory audio system
    12.36%
    11
    From the onboard sound to an aftermarket processor
    2.25%
    2
    From the onboard sound to a head unit
    17.98%
    16
    From a sound card via 1/8" phono to aftermarket amps
    22.47%
    20
    From a sound card via 1/8" phono to the factory audio system
    3.37%
    3
    From a sound card via 1/8" phono to an aftermarket processor
    5.62%
    5
    From a sound card via 1/8" phono to a head unit
    8.99%
    8
    From optical out to an aftermarket amp
    4.49%
    4
    From optical out to an aftermarket processor
    13.48%
    12
    Jan Bennett
    In fact, I voted "optical" because there is no "coax" digital, which is what I use...
    List of front-ends/usefull apps
    XTroniC | XTroniC Direct
      My option is not there.
      "From a sound card via RCA to aftermarket amps"
      Installed
      Asus A7N8X-VM - AMD Mobile Athlon 2400
      512 Ram - 60GB HD - Opus 150w
      Lilliput 7" - Rikaline 6010
      [00000000000001100010-] 98% Completed
      Check Out My Install!!!
        Yeah - 10 options puts a pretty big limit on the poll
        Jan Bennett
          What sounds card?
          Jan Bennett
            phono normally means RCA connector, not 1/8". maybe you can remove that 1/8" phono part... whether through 1/8" stereo jack or RCA/phono is less important...
              I've seen it refered to as both ways...much like people refer to SPDIF as being both Digital RCA and/or Tos-Link
              Jan Bennett
                "From a sound card via 1/8" phono to aftermarket amps"
                Is how mine will be setup as soon as I get around to buying the Audigy 2 NX. In the meantime I'm scraping by on onboard which sucks exceedingly.
                {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
                MY INSTALLATION LOG
                  From 1/8 to a PAC Turbo linedriver to my OEM amp, no HU.
                  GE Cache Builder | me@cardomain |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
                    I believe that "Phono Plug" is generally considered the Correct terminology for the 1/8" and 1/4" single-shaft plugs (like the plugs on an electric guitar cable and amp.) I believe that this terminology came from the old Telephone switchboards that used this type of connector (though only a 1/4" mono plug) in their "patch" cables to route calls to the correct circuit or line.
                    "RCA" connectors are sometimes referred to as "RCA Phono" plugs, but AFAIK calling this just a "Phono" plug is not correct.
                    I don't have my Intel Mac Mini hooked up in a car yet as I'm planning to wait until I get a new car to start fresh with a new system...maybe the new Lotus Elise. I do have my home tower connected to my audio system with the Audigy ZS via a Toslink Optical cable and it's just okay for SQ, but that doesn't qualify me to enter the poll, lol.
                    I wish ESI would make an external USB version of the Juli@ for my Mac Mini! I was also thinking of trying the Optical out from the Mini sent to the Alpine PXA-H701 but I haven't had a chance to test this yet. I guess I should check the Mac Car threads, eh? I already have the Intel Mac Mini as a backup digital capture system for my studio and location photo shoots, otherwise I probably would go with a PC setup for my upcoming car install.
                    Wish I was at the point where I could participate in this poll! Sorry for taking up the bandwidth.
                      I bet this usage originated because RCA plugs were frequently used to connect record players to the "Phono" jack on receivers in the old days...and eventually the terms became somewhat synonymous.
                      Just a guess though.
                      An amateur built the Ark. The Titanic was built by professionals.
                        I use an USB FM transmitter and just play the sounds over my radio
                          Hope you live in no-mans-land...
                          1.9in x 2.9in -- 47mm x 73mm
                            the other way around. RCA plug is also called phono because it was originally made for phonograph (record player) connections exclusively. the telephone connectors (1/4" or 1/8" mono plugs) are called phone jacks, not phono jacks.
                              Nah,
                              I live in a very crowded over populated place and I watch PORN in my car all the time which makes very interesting radio broadcast.
