Will this sound card work?
  • Will this sound card work?
    Is this a good card to use if you are going to use an amp?
    http://www.newegg.com/Product/Produc...82E16829121126
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
    am I seeing that right?
    it only has a single left and single right output? So you could go to one two channel amplifier....only.
    note: for questions like this, please start a new thread, I split this out from the thread you originally posted in.
    Jan Bennett
      The RCA closest to the 'top' is SPDIF. Probably out, whereas the white is probably in. The analog is part of a 'breakout' cable which is shown in some of the pictures.
      Read the review posted on Newegg. It starts off by saying the software doesn't work properly, so automatically it might not be so great.
        if your running a single amp then stereo output froma soundcard shouldn't be a problem. also if your amp has pre-outs then you can run a multi amp setup with a single set of rca outs. for the money though you should look into the silverstone dac. do a search about it on the forums and you'll find a link to a really good review/comparison of that unit.
        will cost you about $100
        edit:
        i did the searching for you:
        http://www.mp3car.com/vbulletin/show...187#post908187
        and here is the dac:
        http://www.newegg.com/Product/Produc...82E16812162002
        http://www.newegg.com/Product/Produc...82E16812162001
        it's actually the same price as the m-audio card
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          That's a lot of RCA's off of one connector!
          1.9in x 2.9in -- 47mm x 73mm
            So 12 different channels to get sound out of? That can't be right...
              8 channels out so will be 7.1. no doubt you can run it in anything 2, 2.1, 4.1 etc etc up to 7.1 though.
                This card is designed for PRO use in studio and home studio environments. It's really NOT the right card for in-car use unless you are planning on having a few different things going on at once.
                "Two analog inputs and eight analog outputs plus coaxial S/PDIF I/O"
                http://news.harmony-central.com/Newp...-Ships-US.html
                I think Newegg has their caption wrong. This doesn't look like it's setup as a 7.1 card at all.
                  just read the title: M-AUDIO 9900-40767-00 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail
                  has RCA out so i like it. (i hate 3.5mm jacks)
