Installing an 4 channel amp for my speakers
  • Installing an 4 channel amp for my speakers
    Hi guys,
    I drive a 04 TSX non navi
    I've just installed a sub and a mono amp. I am going to switch my stock front speakers to alpine type S. Also, i got an Alpine F250 amp to install too. I have no idea how to hook up the 4channel amp to my front and rear speakers (4 in total) Can anyone give me some instruction? hints? links?
    Also, I've used 4AWG power wire for my mono amp. I am planning to use 8AWG for the 4channel amp. Do i need some kind of battery terminal like this?
    Last Q, i need an inverter for my laptop. Right now i'm using the cig lighter type of inverter. however, i want to move the inverter to the trunk with all the audio stuff. What size of wire should i use to power up the inverter?
    Sorry for the many Qs. Thanks in advance guys.
    That could work but why would you want to run multiple power lines. How many watts are you using in total?
    You could use a distribution block (power & ground). Given you are under the allowed wattages through the current power wire that you are running. That way you would split off from main power to each component after the distro
    PROGRESS:
      Hmmm, I'm confused. Main thread title says "Installing an 5 channel amp for my speakers" but first post has a sub title "Installing a 4 channel amp for my speakers". Perhaps if we get that part squared away first.
      http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
      1990 RHD JDM 300ZX TT 2+2 5sp T-Top
      491RWHP / 18psi / 94 octane
        sorry...it's a typo. I tried to edit the title but doesn't work. it's 4 channel amp!
          I'm using the mono amp to power a 12" Type R which is like 500rms. And the front alpine speakers are 50 rms each and the rear speakers are stock, so it's pretty low.
          so do u mean..... i should run the 4AWG wire to the trunk then use a distribution block to split into 2 set of wires?
            changed the title of the thread for ya.
            Also, yes, run a single wire back to a distribution block and split it there. Makes things much easier now and in the long run.
            Jan Bennett
              AlRIGHT! Thanks for changing the title for me. BTW, i only have 4AWG wire. So i should run it from battery to trunk, and then use a distribution block and split it in to 2 8AWG? will it be ok to use 8AWG for my mono amp ? Any suggestion of distribution block? Thanks
                it should be fine. check out the sticky thread for proper lengths and gauge. but in my experiance if your sub amp is 500 watts it can handle an 8gauge as well as the 4 ch that you intend to put in
                PROGRESS:
                  I'd probably suggest any distro block that holds fuses for as many components that you intend to use
                  PROGRESS:
                    You really only need a distribution block in the area where your amps are, and it needs to be fused in addition to a main fuse you should have in your hood compartment. The block near the amps is where you would split it into smaller guages (if you want to go smaller), and have each run on its own fuse. The ground can be distributed as well, but no fuse is needed. As far as type, there are many out there. It depends on what type of fuse you want to use and how you want it to look.
                    DON'T PANIC.
                    Previous install pics in 2k3 S10
                    Project CarPc V2
                      I suppose I should have included this.. http://www.the12volt.com/wiring/recwirsz.asp Check it out, pretty handy.
                      DON'T PANIC.
                      Project CarPc V2
                        Alright, I guess the distribution block and wire issue are clear now
                        for connecting the 4 channel amp to speakers, do i just tap RCAs from HU to the amp and then connect the speaker wires from all the speakers to the amp?
                          you can tap the rca's on the HU if it has front and rear pre-amp outs. If not you'll need to look into a box to step down the speaker outputs of the HU into preamp signals for your amp. I really can't suggest using the high level input on any amp, as they always seem be horrible.
                          ::EDIT:: btw, what monoblock amp do you have, i'm trying to see how much capacity you have left on that 4awg line for your inverter
                            i have an alpine M301 mono amp
                              Well the mono amp uses 2x 20amp fuses, and the 4 chan is using 2x15amp fuses....
                              Leaves ~30amps for the inverter if you want to max the line out, as 4awg has about a 100amp transmission carry ~25ft (about the length from hood to trunk).
                              The inverter shouldn't be any larger than that considering its just for a laptop
