i need help finding the right amp
  • i need help finding the right amp
    ok this is an extention to a question i posted earler. what i need to know is, what is the best amp to power a pair of pyramid hyper pro 500watt speakers. i am trying to build a decent system on the cheap. ive been shopping mostly on cardiscoutstereos.com and im debating between a more expinsive lanzar model found here: http://www.lanzar.com/itempage.asp?MODEL=VIBE236 or a cheaper pyramid model found here: http://www.pyramidcaraudio.com/itemp...p?model=PB717X i'm also planing on buying an amp to power 4 300 watt pyramid 3-way speakers. to let me know your reccomdations they are greatly appreaciated
    Are those ratings in RMS? What's the Ohm rating on the speakers?
      much better then the two you listed: http://www.edesignaudio.com/edv2/pro...products_id=45
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        all the speakers are 4 ohm and the watts i gave you are max, i cant find a listing for rms. what is the lowest price for that amp you suggested, like i said im on a tight budget.
          pm sent with a special price ;-)
          M10k
          My Car Pc Install
          My Boat Pc worklog
            I would follow Scott FX advice. The Elemtanal Design Stuff works great. And the Price is outstanding.
            MtryDoc
            2006 Nissan Titan LE 4x4
            Magetic Blue Crew Cab
            4" Lift by PRG Productions
            Infill T3 HU
            Rainbow Sound Line SLC
            ED Nine.1 Pushing 10v2 Sub
            ED Nine.4 Pushing Components
            "A Wife That Really Loves Me!!"
              Added to favourites
              http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
              1990 RHD JDM 300ZX TT 2+2 5sp T-Top
              491RWHP / 18psi / 94 octane
                Originally posted by jschrauwen View Post
                Added to favourites
                off topic...i haven't forgotten about you...i just can't find the speaker grills. i know they are around somewhere.
                M10k
                My Car Pc Install
                My Boat Pc worklog
                  even at that price it is way too expinsive im looking to spend 60-100 on the amp and what is better about that amp over the lanzar amp
                    Contradicting request - "trying to build a decent system on the cheap". How about "a cheap system on the cheap" or "a decent system on the decent $"? Both units look to have some pretty inflated specs. Either should suit your needs but since you're already started with Pyramid speakers might as well continue with same manufacturer. I've never used either. The bottom line is that you usually get what you pay for - usually.
                    John
                    Thanks Scott. It seems that 3.5" speaker grilles are even rarer to find than the 4" ones.
                      in a nutshell: everything.
                      more specific: components being used what again means better sound-quality, also better components improve the lifetime of it and i think i could go on four hours on this... so what's better? everything, as i said...
                      edit: look at my signature below
                      Xenia & Isabelle, totally in love!
                      'T SQiekenkot: VOLVO 740GL 2.3
                      CarPC: none at the moment
                      CLARION HX-D2
                      CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
                      CLARION APA4300HX => CSS Trio8
                      CLARION APA2100 => Dayton IB385-8
                        what they said.
                        the ED amp is going to be cleaner and more powerful. I'd suggest you hold off until you can afford the ED amp. It'll last a lot longer then that other amp so you wont have to buy another one in a year or so.
                        M10k
                        My Car Pc Install
                        My Boat Pc worklog
                          emttravis,
                          is that emt as in "emt-b"? Take the advice on gettin a better amp. Im from the old school car audio era when pyramid was all there was, which wasnt saying alot then either. Check on sales at best buy or ebay, just picked up a fosgate p2002 200 watt amp for $109.00 out the door, fall is here alot of companies are changing models = good closeout prices. Pyramid was notorius for boasting "500 watts" but we blow them with a punch 45. You wont be disapointed with a better quality amp for starters.
