need alittle help with SPDIF
  • need alittle help with SPDIF
    Okay I got a sp1300 with SPDIF which i wanted to run to the Add51t from Audiobahn then send that to my amps. I have tried everything to get this to work (including calling Mp3car) i dont know whats up Its like i cant get the Spdif to come on.
    what ive tried
    the jumper on the motherboard
    spdif set in a advance windows sound setting and the driver program.
    from what i read im not soposed to get sound from the phono jacks when spdif is on and no matter what i do i keep getting sound out.. anyideas ?
    what ive tried
    search is your friend:
    http://www.mp3car.com/vbulletin/show...if+driver+epia
    you have to update your drivers and install a couple other things
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      So wait I have to have a converter ??? why cant i just run the rca??
        you only need the converter if your processor only has optical in. otherwise everything else should be get you up and running
        M10k
        My Car Pc Install
        My Boat Pc worklog
          aight cool thanks alot
            aight so im confused.. I followed your advice and im still left with nothing... The RCA spdif output goes to the RCA input of the add51t. thats exactly how its hocked up am i missing something here is there anyone that has this installed and how did you get this to work... SHould i just bit the bullet and by the 30 dollar sound card and run optical
