Audi A8 2004 - CD not Readable :(
  • Audi A8 2004 - CD not Readable :(
    Hi all,
    I need your help , when i create my own Audio CD , i get CD no readable message on the MMI when i try the same CD on other cars it work perfect with no problem ... i am using CD-R Media ... please help
    I suggest burning the disc at a slower speed. 8x or less usually does the trick. If it still won't work, you might try using different software. I usually use Nero or iTunes.
    Good Luck.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
      Hi walky_talky ,
      i used Sony CD-R and it worked well. I used both Nero and windows media player ..
      thanks for the help , i will also try your trick with the same CD-R the was not readable on my car.
