AUX Input options
  • AUX Input options
    My laptop only has one MIC input, and no AUX line input. So, I'd like to know what options there are available besides a USB soundcard.
    I'd like to get the Silverstone DAC or similar, but I need an AUX input.
    Have you connected a stereo source to see if the mic input is stereo? If it is, you can just turn the input sensitivity down.
      would that sound quality be equiv to a dedicated AUX source?
        Well, because it'd be passing through the mic pre-amp, even if you turned the input gain down...
        No. You'd need a USB or PCMCIA solution.
          Take my advice: Do not try to build a system that includes EVERY feature. Start with the basics, build it to a bug free state, and THEN add on.
            If your motherboard or soundcard has an input for cdrom type audio connections you can wire up a headphone jack and use those as inputs. I currently use one for my XM radio due to my line in is used by my TV tuner and wanted to leave the MIC open for speech recognition.
            Pinouts
            http://www.epanorama.net/documents/p...udio_wire.html
            Types of cables depending on your SC or MB header
            The jack you'll need
            OR you can get one of these...
            http://www.frontx.com/pro/p090b1_030.html
            2011 Nissan Frontier SL
            AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
            OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
              @Custommx3
              where did you find that jack? local radio shack came up short (big surprise).
              look around on the fry's website, and they carry this:
              http://shop3.outpost.com/product/334...H:MAIN_RSLT_PG
              would that work too?
