need help abt amp and speaker
  • need help abt amp and speaker
    hello friends....
    i need a help i'm new abt cars i brought 1 amp and brought 2 pair of speakers can some tell me if that will work or its gonna blow... the speakers...
    JBL GTO-4000
    SPECIFICATIONS:
    4/3/2 channel amplifier, extremely versatile
    Can drive 4 speakers OR 2 speakers and a sub OR 2 high-powered speakers OR 2 subwoofers!
    4 x 50w RMS or tri-mode: 2 x 50W RMS + 150W for sub
    4 x 100W max or tri-mode: 2 x 100W + 300W for sub
    Bridgeable into 2-channels to produce 2 x 300W
    Variable cross-over. Variable Bass Boost.
    Speaker Level Input
    Overload protection
    Dimensions: 358mm x 55mm x 294mm (WxHxL)
    PIONEER TS-G1647 6 1/2" 2-Way 150watt Car Speakers
    Technical Specification: -
    Sensitivity: 92 dB
    RMS Power Range : 30 Watts
    Peak Power Handling: 150 Watts
    Frequency response: 35-22000 Hz
    Diameter: 6.5 Inch
    Features: -
    PET silver film cone tweeter
    Foamed injection-molded poly woofer
    Fits 6-1/2" and 6-3/4" openings
    Frequency response 35-22,000 Hz
    Recommended power range 2-30 watts RMS
    Peak power handling 150 watts
    Sensitivity 92 dB
    Top-mount depth 1-5/8"
    Toyota Hilux 4x4 Double cab
    Planing [---------------] 80%
    This forum is dedicated to CarPCs and installing them in your car.
    The car audio forum is dedicated to integrating your car audio system with your CarPC.
    For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
    http://www.elitecaraudio.com
    http://www.carsound.com
    http://www.caraudioforum.com
    http://forum.sounddomain.com
    http://www.realcaraudio.com
    http://www.carstereo.com
    http://www.caraudiomag.com
    http://www.termpro.com
    http://www.the12volt.com
    http://www.talkaudio.co.uk
    http://www.caraudiosecurity.com
    et. al.
    There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
    Good luck.
    How about the Wiki?
      moved to the appropriate forum, and
      Jan Bennett
        What's funny is that it's actually what you said.
        I just copied/pasted.
        How about the Wiki?
          yeah - I know - most people are doing it that way now instead of just linking to it.
          which is fine, that's why I wrote it, makes it easier on everyone
          Jan Bennett
