Its Go Time!!!!
  • Its Go Time!!!!
    this weekend is gonna be fun as all hell
    got my speakers last week
    got my amp tuesday
    got my amp power kit thursday
    got my HU (ya ya i know car pc>hu...i agree lol)
    got my wires (RCA's/speaker)
    tonight started all the prep work (took the amp kit into work with me and on down time i worked on getting it hooked into the distro blocks it came with ), soldered most of the connections (the U pieces to the wires), soldered the CD deck wires to the harness i got
    tommorrow morning i am gonna have all kinds of friggin fun before school then goto class pick up a few random things i forgot (and get a hole drilled in my firewall b/c i dont have the tools to be able to do it, nor do i wanna mess with drillin that hole lol, and i got sum1 to do it for free so that works), then come home and work on it some more
    current setup:
    Pioneer DEH-P980BT
    Kicker PKD1 amp kit
    Kicker RCA's and speaker wire
    Elemental Designs NINe .2x
    CDT ES 620's
    next on list:
    Sound Spliiter RL-P Fifteen sub (wanna get Focal KX40 tho lol)
    gonna do a worklog dont worry with plenty of pics
    What kind of car do you have? With what transmission?
      sounds good man, goodluck!
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        2005 Dodge Neon SXT stick...
        so first problem i ran into today (actually 2, but one will be fixed tommorrow)... first was i wasnt able to find a hole for the 0/1 ga wire to go through the firewall and i dont have a drill bit big enough to go through it, so tommorrow im gonna be goin to a local car audio store and they said they would do it for me in about 15 min or so
        now to the real problem (that i think i fixed but want to double check with ppl that have done car audio). i hooked up all the connections from the HU-amp and battery-amp, then amp-> xovers-speakers. when i turned it on there was basically no sound coming from the speakers (very very very faint), so i checked all connections made sure amp was powered, checked polarity etc and thought "what the hell" so messed with the gain and there we go SOUND!!! now my only problem is that on some of the lower end notes the speakers distort more then i think they should. i know this is due to x-over points and the HU/amp (HU has quite a bit of options for slopes and x-over points and EQ and such). while i know its impossible for anybody online to know exactly howto fix it, was wondering if anybody had any similar problems in their install and how they fixed it.
        tommorrow when i goto the car audio store im gonna have one of them come and sit in the car and see what they think needs to be done for SQ (the shop is heavy for SQ and not really big on SPL).... my other problem is i dont have my sub yet (and wont for a bit) so gotta try and mess with this while keeping some of the lower frequencies but not real low as to prevent damageing the speakers
          Your HPF should be at or above 100Hz. Otherwise you're cooking your speaker's coil.
          There should be NO distortion so if there's any, it's too much.
            The ES's should be good down to 60Hz properly installed, a Nine.2X is borderline for 'em though.
            Might want to set your gains with a DMM and make sure your bass boost isn't on.
            As for the x-over, set the one on the amp to full and use the one on your HU. It's a bit easier to change something right in front of you on the fly than it is to climb in your trunk while driving
            Chris Schempp
            Elemental Designs
            Scion tC in progress
              the Nine .2x is rated right for em (200 RMS @ 4 ohm), while ED is not the highest quality, they are still pretty good and should be fine
              shadow thats what i figured which is why once i heard distortion i turned em almost all the way down and tried playing with em some more....
              now mandos whats properly intstalled? they are going in the door which as of now has plastic rings, but will be changed to fiberglass with MDF support... now should i make it a sealed enclosure for em with the glass? or leave em open air?
                well its done, 2 day gauntlet of car audio has been completed back to driveable vehicle standards
                i still have work like fiberglassin new A-Pillars, and getting my HU adapter (for factory mounting) to let the cover fit over it again, but other then that im all set
                however hooked it all up, listening to it with car off while my friend and i finished up, turn it on to go for a ride and..... you guessed it.... friggin engine noise....
                im thinking its a problem with my grounding point not necisarily ground loop per se but basically that i just need a better ground
                  heres some pics of the final install
                    You need to restrain those wires. Go to Lowe's or Home Depot and get some wire holders. They're plastic and shaped like a P. You just put the wires inside and screw them down.
                      now 1 this is not completely done so dont criticize the mess please
                      i have to glass some new A-Pillars to custom mount the tweets (right now they are mounted with double sided tape to keep em there)
                      i have to clean up the amp area (once im done messin with my friggin ground loop issue) and clean the cables up
                      i have to get my 2nd amp and sub still
                      i have to dynamat everything and when i do dynamat (in the spring) i will fix all problems i have and get it show quality install
                      but the biggest part is done (installin HU, cables, mounting amp, putting speakers in, etc)
                        they are restrained, up until the point where they hit the seat
                        and this is only for a few days until i have time to fix ground loop, and tidy up the wires some more
                          Restrain them as close to the amp connections as possible. Wires pull out on accident a lot. Especially on a seat that moves.
                            ill have to pick those up tommorrow (i cant go today )
                              I say borderline for them and suggest the DMM rather than just turning up the gain because we do occasionally get Nine.2X's that bench in the 300W/channel range. The Nine.2X will work great, I'd just trust proper gain settings over ear any day of the week.
                              As for proper install, doors deadened and sealed, preferably with the speakers on an MDF spacer.
                              Chris Schempp
                              Elemental Designs
