Soundstream D' ARTAGNAN 5.1 Question
  • Soundstream D' ARTAGNAN 5.1 Question
    I have a question on a Soundstream D' ARTAGNAN 5.1 . I'm running a Alipine CDA-7878 and it has 6 4 volt pre outs (Channel 1 & 2 front Channel 3 and 4 rear and 5 and 6 are sub channels). The new amp has 6 inputs but shows channel 5 as a center channel and channel 6 as a sub channel. I'm interested in using this amp as a 6 channel and the 5 and 6 channels being used for sub channels off the head unit. Is this possable by maybe plugging the head units sub pre outs to the 5 and 6 channels and bridging the 5 and 6 outputs? then come the problem of the flip switches on the front. (my sub is a DVC) Does any one have one of these Soundstream amplifiers? Thanks in advance, AL.
    You didn't read the sticky on car audio only specific questions did you? Or how about a little
    My best guess is no. But here you go anyway.
    http://www.soundstream.com/manuals/AMP/daamp.pdf
    From what I read you would need another D'Artagnan to bridge it using their BIO port.
    System always under construction
      As far as your first question, no and I'm sorry for my oversight, AL.
        No problem. Hope that info helps.
