my new gadget/sound device
  • my new gadget/sound device
    consider selling this...please see post 11
    my dac finally arrived:
    some notable specs: 122 s/n ratio, 192/24 bit, balanced outputs
    this piece is just a tad bit smaller then my motherboard which will look great on the other side of my trunk under plexi.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    that looks real nice.. is this something that would have to be made again, or are more of these available?
      i think this would have to be made again. It's an eval board:
      Crystal CDB43122 evaluation board http://www.cirrus.com/en/pubs/rdData...s43122eb-1.pdf
      this link may be of use too:
      http://www.diyaudio.com/forums/showt...=&pagenumber=1
      M10k
      My Car Pc Install
      My Boat Pc worklog
        Crystal CDB43122 evaluation board http://www.cirrus.com/en/pubs/rdDat...cs43122eb-1.pdf
        Your first link is no good. That think looks sweet!
        How much was it?
        Where did you get it?
        How does it connect to the computer..or does it?
        System always under construction
          How much was it?
          Seems like its's spdif (optical or coax) input and balanced line out...
          List of front-ends/usefull apps
          XTroniC | XTroniC Direct
            Damn. Not quite what I was looking for. Still seems like a really nice piece.
              How much was it?
              fixed the link. the board; if you can find it, runs about $400 new. i got it for less because it was used. you can try searching on the diyaudio.com site or maybe contact the vendor from the second link i provided.
              and JC was right, coax or optical spdif and xlr (balanced). I'm not sure i would use this unless you have an x-over with balanced inputs and something that ups the output voltage. There is an ldx-23 on ebay right now (what i'm using) or i think you could use a zapco slx-4 (i have one sitting here if anyone is interested). you can convert balanced to unbalanced by ground the -signal wire to the shield, or you can find a handful of amps out there with balanced inputs (some use a standard rca and floating grounds).
              M10k
              My Car Pc Install
              My Boat Pc worklog
                Is the system in your car really nice enough to warrent that? Balanced signals in a car would be pretty wicked.
                Looks sweet man!
                  does my system warrant it? it's beginning to, yes. does my car warrant it...definately not. but i am a fool and like to have a clean signal. :-) The door speakers are going to be swapped out probaby...just because i'm addicted to the hobby and constantly changing. but my tube amps have balanced inputs, my x-over has them, as well as my solid state zapco amp for my sub :-)
                  M10k
                  My Car Pc Install
                  My Boat Pc worklog
                    balanced signals will reject rf interferance... ANY system would benifit from that...
                      thinking about selling the dac and the whole shabang...
                      so i'm thinking about streamlining my signal path since i have a computer and I'm thinking about selling my audiophile grade dac, balanced attenuator, and even my balanced 3 way butler/phaze x-over and i'll also consider selling my phase balanced line driver/converter (turns an unbalanced signal into a balanced signal... of course you wont need that if you get the dac but it's available)
                      this is sort of a unique system but i thought i'd throw it out there in case anyone was interested.
                      here is some info on the components:
                      dac:
                      [media]http://www.cirrus.com/en/pubs/rdDatasheet/cs43122eb-1.pdf[/media]
                      [media]http://www.diyaudio.com/forums/showthread.php?threadid=15551&perpage=15&highlight =&pagenumber=1[/media]
                      volume control:
                      [media]http://www.twistedpearaudio.com/joshuatree/jt.aspx[/media]
                      the x-over is a 'tube' x-over with 12 or 24 db slopes. high pass, band pass and low pass outputs.
                      if anyone wants a high end signal path with no noise this is your way to go. you dont have to have a balanced amp either. you can convert it to unbalanced with one solder
                      M10k
                      My Car Pc Install
                      My Boat Pc worklog
                        lol, selling it for the Behringer?
                        2006 Mazda 3
                        Behringer DCX-2496
                        JL500/1 JL10w6v2
                          considering it :-) still doing research. I'm thinking that any sound degradation that the behringer will introduce will be masked by my loud exhaust but i'll have some added tuning functionality that wont need to be handled by the computer
                          M10k
                          My Car Pc Install
                          My Boat Pc worklog
                            please no
                            screen name here use to be MegaloRESE15"
                              actually the Behringer DCX2496 is regarded pretty highly as an active budget crossover. Nothing can really touch it in this price range. So not all behringer products are junk.
                              Scott why not keep it and feed it into the behringer? Or are you trying not to spend more $$?
