Hi Fi Car Sound Effects Processor Decision Making! Plz Contribute
  • Hi Fi Car Sound Effects Processor Decision Making! Plz Contribute
    Hi Friends,
    I have been looking for really good sound effects processor these days. I want a sound processor which provide high quality sound effects inside my car ,which have easy to use controls and features.
    So I research a bit on various products available in the market. Then I thought of putting my wish list here, so that experts here can comment and help me to take a wise decision. So I welcome everyone to come forward and put your comments and opinions on this.
    I am stuck with 9 products, I have to choose one from it.
    1.Alto UCS PRO
    link : http://www.altomobile.com/main/catalogue_dig_xover.html
    2.Alpine PXA H701
    link: http://www.crutchfield.com/S-rRTVkMs...0&I=500PXAH701
    3. Rockford Fosgate 3Sixty.2
    link: http://www.rockfordfosgate.com/produ...7&locale=en_US
    4. Zapco DSP6 SL
    link: http://www.zapco.com/prod/signal_procs/sigprocFrame.htm
    5. Audiobahn ADD51T
    link: http://www.audioallies.com/GetItem.asp?Item=ADD51T
    6. Eclipse DCU 105
    link: http://www.cardomain.com/item/ECLDCU105
    7. JL Audio CL 441 DSP
    link: http://mobile.jlaudio.com/products_c...hp?prod_id=369
    8. Pioneer DEQ 9200
    link: http://www.zalmar.com/detail-CarElec...o-DEQ_9200.htm
    9. Alto Total Recall
    So these are the choices I have in mind. I just want to know how you think of each and whether I miss anything in the list.
    Thanks a lot.
    take a look in the car audio sub-forum. there is a break down of a lot of these processors and if they will work for us or not.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      mmmm +
      Alto UCS PRo is a multieffect processor which provides Multiband parametric eq, digital compressor, dynamic level control, digital time alignment, its software can able to set delay effects and thereby use reverb and also its 6 channel facilitates dolby surround
      Alpine PXA H701 is a mulitmedia manager for Car DVD sound. it provides Auto-eq which senses the acoutic enviroment inside the car and tunes automatically for smooth listening.it provides surround sound effects too, 31 band graphic eq, 7 band parametric eq, active xover, digital time alignment.
      Rockford fosgate's 3sixty provides OEM integration, 31 band graphic eq, time alignment, auto eq using PDA, delay effects.
      Zapco DSP6 SL provides Qbass for bass boost, xover, eq, time delay effects, gain control.
      AudioBahn ADD51T is a surround sound processor with remote control and sound field effects
      Eclipse DCU 105 provides surround sound for DVD applications inside car ,digital time alignment, xover, 31 band eq
      JL Audio CL 441 DSP is an OEM audio interface , 30 band eq, Auto eq..
      pioneer DEQ 9200 provides Auto eq, time alignment, sound field control effects...
      hmmm.. these the general descriptions i have collected... and i am not much technical but new to this.... I need a good multieffects processor... and these are the produts come to my notice.. did i miss something? or what is best in this list..
        the alpine is the most computer friendly and versatile
        M10k
        My Car Pc Install
        My Boat Pc worklog
          Moved to the Car Audio forum.
          How about the Wiki?
            Agree with Scott_Fx
            Also, the Alto Mobile has the possiblity of noise problems if you do a little searching (Just have to be careful about ground loops). Also the S/N ratio is kind of low.
            Eclipse makes good products but sound adjustments are harder to use than the Alpine. IMO
            Th JL is good if you want to interface with your stock stereo.
            Zapco makes good products. Have never used that processor though.
            Audiobahn- Rumors where that the company is not doing so well. (products are medicore quality)
            I like the Alpine, super easy to use and sounds great!
            The others I have not used or have no experience with.
            System always under construction
              these are not sound effect processors....they don't add in a bunch of effects, no reverb, none of that.
              and I'll back up what others have said, there is an entire thread dedicated to this at the top of the car audio forum, be sure to check it out.
              Jan Bennett
                Alto UCS PRO provides delay, eq, xover, surround ... do check their site
