Canton Pullman 4"
  • Canton Pullman 4"
    Have any of you guys ever used this midrange? It is from the mid to late 90's. I've looked EVERYWHERE for some info on it and can't find anything. Well at least not anything that I can read. I would like to know what frequency range it plays in and wattage. I would really like to run it from 140-6000 but I don't know if it can. If not I've gotta get something else SOON. Thanks for any help
    just give it a shot.
    why not?
    did it come from a 3-way set-up?
    can you read german?
    Jan Bennett
      Here a link to their site.
      http://www.canton.de/en-produktinformationen.htm
      The earliest product info is 03-04 but it does have the 4" driver. The 05-06 .pdf shows the driver as 100w and 48Hz up.
      I know that info is 5-10 years newer but they may not have changed the driver too much. Is your driver aluminum?
        why not?
        I am working with it right now. It came in a 3 way setup and no, I can't read German. It tells me the wattage for the whole component set but not individual speakers.
          They changed the driver alot. It is not aluminum. The company has changed hands since this stuff was out. A guy I know tells me that it is kinda like the old MB Quart stuff. It actually does really well though. I have been playing around with it in different locations and I will be using it.
            well, as long as you're not going insane or severely under powering it, I don't think there will be a problem at all.
            the frequency response....just tune, it either sounds good where you have it or it doesn't....just have to play with it to see!
            Jan Bennett
              Well I will definately have the power. I've got them positioned where they need to be to get a good height and all. I've still gotta work with the tweeters as well. I'm waiting on my adapter to use on my w200 so I can actually get into the menu for the H701.
