newbie wiring question
  • newbie wiring question
    Ok i am installing two full range boxes in a truck, each with a speaker and 12" sub. I also have two different amplifiers (one is a 400w visonik other is a 200 jenson, each is 2 channel 2ohm stable). My question is how can i wire these 2 amps to both boxes? Would the attached diagram work?
    blah mixing & bridgin amps FTMFL
    fullrange?...?
    my best suggestion with that equipment would be 1 amp per sub or just use 1 amp period on both subs.
    screen name here use to be MegaloRESE15"
      it sounds like he's making a 2-way speaker cabinet like home audio. Personally i wouldn't do it but ifyou really want to then i'd on chan to a woofer, the second chan on the same amp to the second woofer, then on the other amp wire one chan to the 'fullrange' speaker and then the other chan from the same amp to the other fullrange speaker.
      New System in progress:
      M10k
      Phaze TD1500 ~> Seas g18rnx/p
      Zapco Ref 500.1 ~ 12" tc-9
      Transflective Xenarc
      My Car Pc Install
      My Boat Pc worklog
        he said truck so its not home audio..im assumin
          oh i know...it sounded to me like each speaker cabinet was going to have two speakers in it. a sub and a fullrange (coax?)
          M10k
          My Car Pc Install
          My Boat Pc worklog
            we all love rear fill don't we
              M10k
              My Car Pc Install
              My Boat Pc worklog
                my thoughts exactly
                  I hope the OP wasn't run off.
                  On a constructive note. If the two speakers are going in the same box, seperate the enclosures. Make it so that the sub has it's own enclosure and the full range speaker has it's own as well.
                  Wire up the sub amp ONLY to the subs and the full range amp ONLY to the full range speakers.
                  Since its in a truck, I'm guessing he's looking for some more volume as most trucks a very limited on the number of speakers...especially if it's a single cab and it's an older truck.
                  Jan Bennett
