Help me pick out Subwoofers! Fun! 2400 Watt Amp.
  • Help me pick out Subwoofers! Fun! 2400 Watt Amp.
    I'm looking to get some new subwoofers for this amplifier.
    SPL Z1X-2400D 1 Channel Car Amplifier-2400 Watts
    900W @ 4 Ohms RMS, 1400W @ 2 Ohms RMS, 1800W @ 1 Ohms RMS, 2400W Maximum Power
    Fully Regulated PWM Power Supply
    Four Way Protection Circuit
    1 Ohm Stable Stereo
    Bridging Synchronization
    Variable Low Pass 50Hz-150Hz
    Variable Subsonic Filter 15Hz-40hz
    Variable Subwoofer EQ @ 45Hz
    Phase Switch 0-180
    Frequency Response: 15Hz to 150hz
    S/N Ratio: 100 db
    THD: 0.5%
    System Distress Indicator
    Inputs Sensitivity: 200mv - 8v
    Dual Mono Speaker Output Connectors
    Gold Plated Heavy Duty Power & Speaker Terminals
    Dimensions: 15" x 11.25" x 2.25
    I have a 1999 Jeep Cherokee, so I was looking for something boxed to fit into the back. I didn't really want to spend over $400. If you guys would recommend anything, let me know. I'm looking for some Infinity or JL Audio dealers near me, tomorrow.
    Tell me if I'm crazy, or if you have any suggestions. Thanks in advance.
    that amp doesn't get near 2400 watts.
    Fuses: 30Ax4
    so, 120 amps, times 12 volts, is 1440 watts, at 80% efficiency that's 1150 watts....and that's pretty optimistic.
    Count on around 800wRMS
      Thanks for the feedback.
      So what do you think I should get for it? I just didn't want to buy something and blow it out the water, you know?
        Fuses: 30Ax4
        i got different numbers, i used 14.4 (car is on)
        120 x 14.4 = 1728
        80% efficeint = (1728 * 80)/ 100 = 1382.4
        also optimistic since i factored a car always being on to listen.
        how about and iDMax, or a Fi Q or an SSD?
        screen name here use to be MegaloRESE15"
          Yea, if only I knew what those were.
          Would you happen to have a link to any of these items?
            ficaraudio.com free shipping on all their subs.excellent products.
            youd have to google Image Dynamics audio. im posting from phone right now.
              You could always check out Digital Designs or Stereo Integrity as well.
              www.innovativerides.com
              Check out the white toyota tacoma in the gallery :)
              References:
              www.ebay.com (NisAznMonk)
