Radio control with iBus ???
  • Radio control with iBus ???
    Is there any way to control the radio cotrol of the stock BMW stereo with an IBus controller. What about the A/C controls?
    Can you, then, control any of them through Road runner (or any other front end and/or software) ?
    That way you could put the stock stereo in the trunk (that way you donīt need a line driver), you just hook up an aux input to the stereo (for car pc) and still be able to use the stock radio.
    _____________________________________________
    If you made your own skin, visit
    The CAR PC NETWORK SKIN PAGE
    at the
    CAR PC NETWORK
    There is no way to control a radio through IBus. You can send some info like RDS station name or something alike but no way to force radio to switch to the certain mode
    Car pc integration with ease
    Car mediacenter
      Here you go:
      Steering Wheel Buttons
      Addr Description Frame data Comment
      50 Next: Press 50 04 68 3B 01 06
      50 Previous: Press 50 04 68 3B 08 0F
      Navigation / GPS
      7F City 7F 23 C8 A4 00 01 42 45 52 4C 49 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2F In this case BERLIN
      7F Latitude / Longitude 7F 14 C8 A2 00 00 52 33 19 40 00 13 11 51 70 00 00 00 11 00 00 0B In this case Latitude 52° 33' 19.4'' / Longitude 13° 11' 51.7''
      7F Street 7F 23 C8 A4 00 02 48 4F 48 45 4E 5A 4F 4C 4C 45 52 4E 52 49 4E 47 3B 00 00 00 00 00 00 00 00 00 00 00 00 00 13 In this case HOHENZOLLERNRING
      Board Monitor Buttons
      F0 1: Press F0 04 68 48 11 C5
      F0 1: Press > 1 second F0 04 68 48 51 85
      F0 1: Release F0 04 68 48 91 45
      F0 2: Press F0 04 68 48 01 D5
      F0 2: Press > 1 second F0 04 68 48 41 95
      F0 2: Release F0 04 68 48 81 55
      F0 3: Press F0 04 68 48 12 C6
      F0 3: Press > 1 second F0 04 68 48 52 86
      F0 3: Release F0 04 68 48 92 46
      F0 4: Press F0 04 68 48 02 D6
      F0 4: Press > 1 second F0 04 68 48 42 96
      F0 4: Release F0 04 68 48 82 56
      F0 5: Press F0 04 68 48 13 C7
      F0 5: Press > 1 second F0 04 68 48 53 87
      F0 5: Release F0 04 68 48 93 47
      F0 6: Press F0 04 68 48 03 D7
      F0 6: Press > 1 second F0 04 68 48 43 97
      F0 6: Release F0 04 68 48 83 57
      F0 AM: Press F0 04 68 48 21 F5
      F0 AM: Press > 1 second F0 04 68 48 61 B5
      F0 AM: Release F0 04 68 48 A1 75
      F0 Clock switch: Press F0 04 FF 48 07 44
      F0 Dolby: Press F0 04 68 48 33 E7
      F0 Dolby: Press > 1 second F0 04 68 48 73 A7
      F0 Dolby: Release F0 04 68 48 B3 67
      F0 Eject: Press F0 04 68 48 24 F0
      F0 Eject: Press > 1 second F0 04 68 48 64 B0
      F0 Eject: Release F0 04 68 48 A4 70
      F0 FM: Press F0 04 68 48 31 E5
      F0 FM: Press > 1 second F0 04 68 48 71 A5
      F0 FM: Release F0 04 68 48 B1 65
      F0 Menu switch: Press F0 04 FF 48 34 77
      F0 Menu switch: Press > 1 second F0 04 FF 48 74 37
      F0 Menu switch: Release F0 04 FF 48 B4 F7
      F0 Menu turnknob: Clockwise F0 04 3B 49 81 07
      F0 Menu turnknob: Counterclockwise F0 04 3B 49 01 87
      F0 Menu turnknob: Press F0 04 3B 48 05 82
      F0 Menu turnknob: Press > 1 second F0 04 3B 48 45 C2
      F0 Menu turnknob: Release F0 04 3B 48 85 02
      F0 Mode: Press F0 04 68 48 23 F7
      F0 Mode: Press > 1 second F0 04 68 48 63 B7
      F0 Mode: Release F0 04 68 48 A3 77
      F0 Next: Press F0 04 68 48 00 D4
      F0 Next: Press > 1 second F0 04 68 48 40 94
      F0 Next: Release F0 04 68 48 80 54
      F0 Previous: Press F0 04 68 48 10 C4
      F0 Previous: Press > 1 second F0 04 68 48 50 84
      F0 Previous: Release F0 04 68 48 90 44
      F0 Radio / Bord Monitor: Press F0 04 68 48 30 E4
      F0 Radio / Bord Monitor: Press > 1 second F0 04 68 48 70 A4
      F0 Radio / Bord Monitor: Release F0 04 68 48 B0 64
      F0 Radio Power: Press F0 04 68 48 06 D2
      F0 Radio Power: Press > 1 second F0 04 68 48 46 92
      F0 Radio Power: Release F0 04 68 48 86 52
      F0 RDS: Press F0 04 68 48 22 F6
      F0 RDS: Press > 1 second F0 04 68 48 62 B6
      F0 RDS: Release F0 04 68 48 A2 76
      F0 Reverse Play: Press F0 04 68 48 14 C0
      F0 Reverse Play: Press > 1 second F0 04 68 48 54 80
      F0 Reverse Play: Release F0 04 68 48 94 40
      F0 Select: Press F0 04 68 48 20 F4
      F0 Select: Press > 1 second F0 04 68 48 60 B4
      F0 Select: Release F0 04 68 48 A0 74
      F0 Telephone: Press F0 04 FF 48 08 4B
      F0 Telephone: Press > 1 second F0 04 FF 48 48 0B
      F0 Telephone: Release F0 04 FF 48 88 CB
      F0 Tone: Press > 1 second F0 04 68 48 44 90
      F0 TP: Press F0 04 68 48 02 E6
      F0 TP: Press > 1 second F0 04 68 48 72 A6
      F0 TP: Release F0 04 68 48 B2 66
        do you have to code for headlight swtich 'off' and 'on' ?
          Check this thread. These are the codes send by the light switch in an 1996 E39. Don't seem to work on an E46 however.
          Edit: I just noticed it was you itsduke. So you allready know about this thread... But check it anyway. I've replied to your last post.
          BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
          Bezel Worklog-My Install -iDrive F01 RR Skin
