Processor Options
  • Processor Options
    • Alpine PXA-H700/701 and RUX-C700/701 - MSRP: $550 and ???
    • Clarion DVC920 and DVH940 - MSRP: $150 and $250
      See this thread for discussion about this option.
    • Clarion ADCS1
      • Tuner -
        • 18 FM/6 AM
        • Station category search tuning
        • 60 station memory call letter display
        • Magi-Tune(tm)+FM
      • CD -
        • Full logic CD controls
        • Programmable play 99 tracks
        • Track music search FF/FB
        • Audible FF/FB
        • Last position memory
      • CD changer control -
        • 100 CD title memory display
        • Direct disc select
        • Multi-changer control capability
        • Audible FF/FB
      • DSP -
        • 5 preset sound balance memories
        • 5 sound field memories
        • 7 adjustable sound field parameters
      • EQ -
        • 4 channel, 6 band digital parametric EQ
        • Selectable center frequencies, 31 points, 1/3 octave
        • Adjustable Q
      • X-over -
        • 14 channel digital crossover
        • Selectable crossover points
        • Selectable crossover slopes 12dB, 24dB, 36dB/octave
        • Phase selectors
        • Adjustable gain controls
        • Independent adjustable time alignments
        • 5 preset memories
      • Audio -
        • Digital audio controls
        • Digital fiber optic connections
        • 20 bit 4 channel D/A converters
        • 8 times oversampling
      • General -
        • Switchable illumination
        • User infrared remote control
        • Programming infrared remote control
        • RS-232 port for parameter programming from computer
    • Audiobahn ADD51T - MSRP: ???
      • 1/2 Din 5.1 Dolby® digital, DTS® surround sound decoder with remote DSP — PCM, Dolby® Digital (AC-3, DTS&#174, Pro Logic® II, Pro Logic®, Movie, Music
      • Two Digital Inputs — Optical and Coaxial
      • Three Analog Inputs — RCA
      • Six 9v Audio Outputs (LF, RF, C, LR, RR, SUB)
      • Two composite video signal inputs
      • One 2.2 volt composite video signal output
      • Delay functions
      • Sound field effects
      • Dimensions: 7/8" (H) x 7" (W) x 5 1/8" (L)
    • Sherwood X-DTS80 - MSRP: ???
      IF you can find this unit, it's another option. It's no longer being made. At the time of this posting, I found one on e-Bay going for $40. New in the box. It's not a super high quality unit, but it's deffinately an option for some.
    • Pioneer DEQ-P8000 - MSRP: $500
    • Pioneer DEX-P9 and DEQ-P9
    • Pioneer ODR system
    • Panasonic CY-AC300 - MSRP: ???
    • Alto UCS Pro - MSRP: ???
    • Zapco DEQ P8000 - MSRP: $500
      • 5.1-Channel Digital Audio Processor
      • Built-in Dolby® Digital / DTS™ / Dolby® Pro Logic® II* / Linear PCM Decoder
      • 24-bit 6-Channel DAC & 6-Channel DSP
      • Digital Sound Control (6 modes)
      • Time Alignment & Speaker Set-up Mode
      • 4.1-Channel Down Mixing
      • Multi-Channel AUTO-EQ Setting (Mic Included)
      • Multi-Channel AUTO-Time Alignment (0 ~ 200inch)
      • MOSFET50 (50W x 5-Channel High Power)
      • 6-channel Hi-Volt Preouts (Front L&R, Rear L&R, Center, Subwoofer) (5V)
      • High-Pass Crossover: 63/80/100/125/160/200Hz
      • Subwoofer Crossover (LPF): 63/80/100/125/160/200Hz, +/-10dB
      • 3-Band, 3-Channel Parametric EQ (Center, Front, Rear) with 7 presets (5 fixed, 2 custom)
      • Listening Position Selector
      • Source Level Adjuster (SLA)
      • 2 Optical Inputs (1 for DVD main units and 1 for DVD source players)
      • IP-Bus Input/Output
      • 1-Day Back-up Memory
      • Optional Center Channel Speaker (TS-CX7) is available
      • Optional Multi-Channel Controller (AXM-P8000) required for use with AVIC-N1 and AVX-P8DVD
    • Eclipse 39011 - MSRP: ???
      • Surround Processor
      • Maximum Output Level: 7.7 volts
      • Frequency Response (20 to 20,000 Hz, referenced to 1,000 Hz): +0.0, -1.2 dB
      • Channel Seperation: at 1,000 Hz, 72.8 dB; at 20,000 Hz, 76.3 dB
      • Dynamic Range (A-weighted, referenced to 0 dB): 99.9 dB
      • S/N Ratio (A-weighted, referenced to 0 dB): 97.6 dB
      • THD Plus Noise (with 1,000 Hz): at 0 dB, 0.02%; at -20 dB, 0.03%
      • D/A Linearity (at -90 dB): +0.6 dB
      • Interchannel Phase Error (at 20,000 Hz): 1.2 degrees
      Eclipse Radio's equipt with onboard DSP controllers can benefit from the 39011 Digital Sound-Field Processor, transforms the mobile environment into an acoustical sound stage. It answers the question "Can I use an outboard D/A Converter with my Eclipse radio" Yes! The 39011 incorporates the highest level of processing technology around the most advanced Burr-Brown D/A Converts in the world. The ultimate in sound quality, accuracy, reproduction.
      The 39011 DSP processor if flexible, with 2-Optical Digital inputs, 1-RCA Digital input, and 2-Stereo Analog inputs (Analog-1 Analog-2).
      When connected to an A/V Theater environment (DV3101 DVD or 55090 DVD/Tuner, the 39011 accurately reproduces the ultimate mobile 5.1 theater sound. The ambience and quality of its original recording, are accuratly replayed within the vehicle, due inpart to the advent of the Eclipse Haas Processing algorithum. Features Exclusive ECLIPSE DSP circuitry using Haas effect delivers true 5.1 Channel sound to every seat simultaneously. The Digital Dynamic Range Compressor (DDRC) automatically adjusts sound levels at different frequencies for in-vehicle enjoyment. Sound alignment adjusts the sound stage to the specific interior size of your vehicle. Choose from multiple sound settings to optimize sound playback based on listener locations. A nine-band graphic equalizer adjusts sound characteristics separately for front and rear seats. The 39011 adjusts to different system configurations, sending different sound frequencies to speakers based on the number of speakers and their locations. A built-in 20-watt center channel amplifier simplifies the task of adding a center-channel speaker to your system.
    • Audiocontrol DQXS - MSRP: ???
      • Six Channel Three-way Crossover
      • Six Input and Eight Output Channels
      • One-third Octave and One Half Octave Equalization Controls per Channel
      • Two Parametric Equalizers per Channel
      • 142 Total Equalization Filters
      • Outputs for Front Highpass, Front Bandpass, Rear Highpass, and Subwoofer Outputs
      • 24dB/octave Linkwitz Riley Alignment Crossover Slopes
      • Eight User Programmable Memories
      • Utilizes an Audio Enhanced DSP
      • Output Level Controls
      • Input for Optional DDC (Digital Dash Control)
    • Audiocontrol DQX - MSRP: ???
      • Digital Car Audio Equalizer and Crossover
      • Two Input and Six Output Channels
      • Thirty Graphic Equalization Controls per Channel
      • Two Fully Adjustable Parametric Equalization Controls per Channel
      • Three-way Digital Electronic Crossover
      • 24 bit Digital Audio Processing
      • 8 User-Programmable Memory Settings
    Jan Bennett
    alto mobile UCS?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
      find me an english page about it and I'll put it up in the list...lol
      EDIT: found one finally. This looks like a very interesting unit.
      Do you have any experience with it?
      Jan Bennett
        not personally, no (not yet that is, because it isn't exactly cheap). but i've read pretty darn good reviews about it!
        CLARION HX-D2
          you see, finaly the newbies got their car-audio informant on this carputer-forum.
          CLARION HX-D2
            down side - no optical in, and output voltage isn't very high either 2.2v
            and it's only 5 band eq....
            Jan Bennett
              the UCS? damn.... ok, never trust reviews! ( I never realy looked into it, because I was going with a 31-band graphiq EQ at first.
              ok, no optical in/out, and indeed rather low output, but: time-alignment
              CLARION HX-D2
                How about the venerable Sony XES (P1, X1)? Also possibly the XDP9000 (Sony).
                What about the Pioneer P9 combo? (DEX-P9 and DEQ-P9)
                As long as I'm chiming in, the Pioneer ODR system and the Clarion ADCS1 may have also had optical inputs.
                  I can't find any specs on the XES nor can I find anything at all on the XDP
                  done - though I think this might be a bit on the sides lines, it's still a player for those that are interested in still using a fully functional HU.
                  Same with the ORD system. This isn't so much just a list of processors that are avaliable, but a list of processors that people might use to research their options as far as integrating into a CarPC install.
                  Jan Bennett
                    As far as the XES is concerned:
                    3/4 way crossover, selectable crossover points, 72dB/octave slopes, as well as time alignment for each channel with the X1 unit. There is a parametric EQ included in the P1 (Command module)
                    Toslink in and I believe there were 20 bit Burr-Browns on each channel. They may have been 16 bit, though. I had one of these setups for quite a while. It used what is by far the most ergonomic remote ever developed for car audio (IMO). Another possible bonus is the X1 may be able to be controlled via PC with a unilink emulator. This unit would function on a standalone basis if that was the case, and be very attractive to the members of this forum.
                    This system also used Unilink for control, and has a niche following currently as far as modifications go (XM/Ipod control.) Here's a reputable forum: http://www.rush2112.net/phpBB2/viewf...55cfeff063f71b
                    The XDP4000X (Screwed up the model # above. It's been a while..) was a very similar unit as far as functionality, but I can't recall the differences.
                    I have a friend currently running the ODR, and it has similar functionality to the XES setup, but with fewer boxes.
                    I will be running the P9 stuff in the install I am planning now. Hopefully I will get a thread started in worklogs over the next couple of days.
                    I realize you weren't necessarily looking for all of the options, but I figured I'd toss out a few SQ heavy options for those on more liberal budgets.
                      I guess the biggest issue I see with the Sony's is that they aren't readily avaliable. Kinda like the Sherwood, it isn't readily avaliable either.
                      While I beleive that the sonys and the pioneers are great units for SQ, I feel that most people who would be purchasing something of that magnitude would already be aware of them and wouldn't necessarially be coming to this forum looking for them?
                      dono - if you can find me some more information on these units and a link, I'll put them in the list, otherwise...it's kinda like the Sherwood (no, not in terms of quality, but rather useful information)....more of a space taker...lol
                      Jan Bennett
                        This is what I found (PDFs of owners manuals):
                        XES-P1
                        http://www.docs.sony.com/release/XESP1.PDF
                        XES-X1
                        http://www.docs.sony.com/release/XESX1.PDF
                        XES-T1 (Tuner)
                        http://www.docs.sony.com/release/XEST1.PDF
                        XDP4000X
                        http://www.docs.sony.com/release/XDP4000X.PDF
                          That Alto UCS doesn't have digi/opti inputs from what I see. Doesn't look like it would do what I want. THough, I guess you can run out the onboard sound to it as it accepts a very low >2v input.
                          Brent
                          1999 Nissan SE-L - turbo toy
                          1993 Nissan NX - Turbo Racer
                          Standalone fuel management (AEM EMS) on both
                          carPC
                            *ahem*
                            Jan Bennett
                              LOL! You realy want all the honours don't you....
                              CLARION HX-D2
