Behringer DCX2496 -- dc power supply
  • Behringer DCX2496 -- dc power supply
    for those of you that are interested in an alternative to the h701 this may be up your alley:
    http://www.behringer.com/DCX2496/index.cfm?lang=eng
    with this mod:
    http://www.diymobileaudio.com/forum/...ad.php?t=19371
    just thought id throw it out there. btw, the behringer has a spdif input. the chassis looks big but i'm sure you could hack it apart and condense it. hell, talk to veritas_forge and he could probably make a custom case for it
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    And don't forget, the Behringer has a serial port and software to control settings via PC.
    System always under construction
      with this mod:
      Wow, you guys are fast. Thanks so much for spreading the news.
      Aaron
        aaron-
        I'd sticky this for you but I think you should contact mp3car first to make sure they are ok with that per forum rules
          if i would have know about this about 6 months ago i would have jumped on this combo to test out in my system :-( I would have been a perfect candidate :-) pc, balanced inputs on my amps and fully active! damn it!
          M10k
          My Car Pc Install
          My Boat Pc worklog
            how small do you think you could get that behringer if you took it out of the case? do you have a top down of all the components inside the case? do you need to have the front panel connected to have the unit work? (wont need that since i'll have a pc)
            M10k
            My Car Pc Install
            My Boat Pc worklog
              hmmmmmmm... just when my sound card turns out to be backordered....
              2006 Mazda 3
              Behringer DCX-2496
              JL500/1 JL10w6v2
                it has a digital in... but it's an xlr connection... would this work with a digital line out from a soundblaster?
                2006 Mazda 3
                Behringer DCX-2496
                JL500/1 JL10w6v2
                  Scott-
                  Steve aka Whiterabbit took his apart I believe. YOu might want to contact him over at DIYMA.
                    great, i'll track him down.
                    thanks
                    M10k
                    My Car Pc Install
                    My Boat Pc worklog
                      the owners manual states spdif input so i'd contact them before you go this route, but this link may help you:
                      http://www.rane.com/note149.html
                      or this:
                      http://cgi.ebay.com/HOSA-ODL-312-OPT...QQcmdZViewItem
                      M10k
                      My Car Pc Install
                      My Boat Pc worklog
                        or this:
                        You would need either the box linked on ebay, or the instructions in the document from RANE, as the input on the Behringer is an AES/EBU and not straight SPDIF.
                        So..what he said.
                          Originally posted by durwood View Post
                          aaron-
                          Thanks, Durwood. I was in the process of asking them about this when someone already posted to the forum.
                            So..what he said.
                            the manual says it's straight s/pdif too though... i wonder if a simple cable would actually work.
                            http://www.sweetwater.com/store/detail/K2Digi/#anchor
                            i think it has something to do with the new chipsets can actually handle the lesser signal of s/pdif as well as still handling aes. I have been researching this a bit now :-)
                            M10k
                            My Car Pc Install
                            My Boat Pc worklog
                              If you have the money,it is more expensive then the HOSA,but it can do more:
                              http://www.audiolines.com/product.ph...cat=218&page=1
                              (Behringer ULTRAMATCH PRO SRC-2496)
