8 channel sound card control thru software?
  • 8 channel sound card control thru software?
    So I'm wanting to take a 7.1 sound card to get 8 channels out and configure it thru software as such:
    Output 1: Front L/R
    Output 2: Rear L/R
    Output 3: Subs (pair)
    Output 4: Center (one center)
    I haven't purchased the sound card yet. Is there a card and software program that will allow me to control my output signals independently and essentially provide a 5.1 sounding environment from a DVD on a 7.1 card? Basically, I have a pair of subs that I would like to provide signals independently and have a 5.1 surround sound field. I'd rather not split the output to my sub amp... Possible?
    AudioMulch with ASIO drivers and you should be good to go!
    I haven't configured mine to use a 5.1 input signal (digital?), so I'm afraid I can't help you there...
    I just use stereo L/R input for Front L/R, Rear L/R, 1 sub and a pair of VU meters.
      what is a vu meter? and why do you need one?
      Carputer to sell : http://www.mp3car.com/vbulletin/vbcl...?do=ad&id=2684
        What is VU-Meter? LINK
          Output 1: Front L/R
          Output 2: Rear L/R
          what are FR/FL/RR/RL output? i am very confusedˇˇˇ sorry, i know a little about the output and input..
            FR = Front Right
            FL = Front Left
            RR = Rear Right
            RL - Rear Right
            How about the Wiki?
              vu meters would be used to verify that you have a good signal level in the software, esp when your speakers aren't working, or you have the wrong outputs hooked up in the software.
              Wungun has used audio mulch for a while, so he is just as biased as i am when i say to try out Console, asio4all, and Virtual audio cable.
              just as a note, i have not been very successful with cards with asio drivers built in, although it could just be me... asio4all would allow you to use wdm drivers in a program like console, or audio mulch.
              although i have not tried surround sound, so i can't help you very much there either-- though if you are interested in stereo upmixing, try spatmixer--i have not tried it, but should allow you to upmix a 2 channel source to 7.1(google says up to 12 channels output).
              also why are you interested in stereo subs, and surround sound? it would be easier, to have a mono sub output, you will experience louder(and possibly lower extension) output when both subs are working in together.
              next project? subaru brz
              carpc undecided
                Is there a way to assign hotkeys or use girder to control levels in either audiomulch or console...
                I've got an m-audio fw 410 , and I've tried everything to send commands to it's mixer, with no avail....
                What I'm trying to do is be able to control the output levels to each channel via RR.
                I'm wondering if I switch to asio plugins and a console, will I be able to acomplish this...
                Thx, and sorry if this is sidetracking OP...
                Sig, smig...
                Ford Flex Toshiba Excite 7.7 Install
                CoverMess - Cool Flash Covers
                FlashFlex - Flash Components for your skinning pleasure
                Mazda Millenia, Road Runner
                YouTube - Road Runner, IGO8 PC, Dashcommand OBD, Visteon HD Radio
                  I have a audiotrak maya 7 with 4 sets of stereo rca output and the hardest bit about it was setting up console.
                    Not sure about audiomulch or console, but Reaper definitely does it for me. I can control it through Road Runner this way, though i prefer to use my Space Navigator directly for this purpose
                      Cool...I've played with reaper and other daw recently...reaper is definately the best bang for the buck....however i really prefer the patch bay type interface like audiomulch...just to damn expensive...
                      I've recently discovered Pure Data ... http://puredata.info/ .... basically an open source daw/console with unlimited flexibility!! It even takes vst plugins...it is based/similar to the commercial sw Max/MSP....
                      Anyway not to ramble on....I am now running it instead of audiomulch with no probs yet...very light on resources too...
                      I have also integrated a Novation Nocturn ( http://us.novationmusic.com/products/nocturn?option=1 ) midi surface with my patch to control anything I want...at a low driver level...when i adjust the sliders on the screen it also updates the encoder's led's...
                      I am building my own midi controller based on this project .. http://www.ucapps.de/ so that i can place knobs and sliders ( motorised too! ) anywhere i need them..
                      So basically , I am now trying to build a Pure Data based custom console for 3 way front stage and sub processing (xover/gains/eq/phase and TA) with rr integration and midi control surface integration.... all open source ...wish me luck
                      Sig, smig...
                        PCPete,
                        Would you post a tutorial on how to get PD up and running as a "console replacement" item. Looks like it would take less system resources.
                        Hans
                          No problem Hans, I was planning on creating a new post once I had streamlined/tested things a little better....I also posted some questions on pd's forum .... hopefully have something over the weekend...I could post my patch if you want it...
                          Sig, smig...
                            I will be honest, and I dont quite understand how PD works yet, and if your patch would help configure my system. I like the gui functionality of console, but not the bloat. When you figure it all out, posting a guide on how to get the standard routing and VST hosting capability would be greatly appreciated.
