what handheld devices are compatible
  • what handheld devices are compatible
    Hi everyone.
    I have the usb connection OBD reader and use this with my brothers laptop.
    However is there a hand held device I can use instead with software available for PC's and what devices are available?
    ie PSP, PALM, IPAQ etc?
    It helps if you tell what kind of OBD reader you have.
    But chances are you will not be able to use it on any PDA.
    Serial OBD2 interface is a better choice when you need to use it with PDA.
    If you need USB, just buy a USB to Serial Converter.
    Most USB OBD2 Interfaces use a converter chip anyway and you do not have any speed advantage over serial.
      I have the top one on this page:
      I am just sick of dragging round a laptop and wanted to know if any handheld devices work well, what do other people use etc?
      many thanks,
        No, it won't work with any pda.
        get an Elm based serial or bluetooth interface if you want to use a PDA.
        PDA serial hotsync cables can be hard to come by for some PDAs. So if your PDA supports bluetooth, it's better to invest in a Bluetooth interface. The bluetooth interface will connect to a PC just fine as well.
          Mok is correct the USB interface will not work with any PDA's, since the PDA behaves as a client USB device and expects to be connected to a host.
          We make a serial interface that works with PDA's and Pocket PC's, you can find it at
