simulator
  • simulator
    Hi , i want to test my Software towards each PID to be sure about Results , and i need your help , could you please give some Hex exemples :
    for exemple :
    To test the Engine RPM : 41 0C 1A F8 = 1726 is this Correct .
    could you please privide me with other PID Hex exemples
    many thanks
    I'll send out a couple here:
    Engine Coolant Temperature -
    REQUEST PID is $05
    RESPONSE EXAMPLE: 41 05 55 = 45 Degrees Celsius where $55 = 85-40
    EXAMPLE 2: 41 05 00 = -40 Degrees Celsius where $00 = 0-40
    Vehicle Speed:
    REQUEST PID is $0D
    RESPONSE EXAMPLE: 41 0D 35 = 53 KM/H where $35 = 53 (no scaling on this one)
    EXAMPLE 2: 41 0D FF = 255 KM/H (slow down)
    Hope this helps. You can always find the rest in the J1979 documentation from the SAE website.
    Hack your car's CAN BUS at www.canbushack.com
      Can you please explaine me the is difference between the Metric / english units , how to get the difference .
      many thanks
