Drivers ELM 327 USB
  • Drivers ELM 327 USB
    Hi, I just installed my OBDII cable, but i can not find the drivers anywhere...
    it's an ELMscan 327...
    I searched for the drivers (on scantool.net) but the ones I downloaded from there don't have a setup file included, and when i let windows search the drivers in the folder I extracted the files to, windows cannot find any...
    I'm using windows XP
    can anyone help me?
    ps: it's an elmscan with USB
    Greetz
    Dj NRG
    Have you checked your installation disk for the driver?
    You should contact the seller and inquire which USB chipset your unit is using.
      I don't have the cd no more (or can not find it anymore ) so I will have to download the drivers somewhere...
      i think i may have found them... will try to install them tomorrow..
      Greetz
      Dj NRG
        usually, when you find a solution to an issue, posting that solution is generally beneficial, especially for the other members of the fourm. For instance, this guy could have used the link: http://www.mp3car.com/vbulletin/1160678-post13.html
        Jan Bennett
          thx for pointing that out, but I was not able to fix my problem.
          the drivers i found were not the right ones, and i stopped trying to get obd2 to work.
          Greetz
          Dj NRG
            ive got the drivers but it still doesnt wrk
              could you send me the drivers?
              then when i have time i might try to get obd to work...
              Greetz
              Dj NRG
                ive taken winzip and acrobat reader out to save space on the file
                Ive also got it workin
                it was not workin because my touchscreen was not compatible in the scantool program so i used keyboard shortcuts.. hopefully a mouse would work better than a touchscreen.
                  thx!
                  will try to get it to work once i've got some time
                  Greetz
                  Dj NRG
                    how did you get the drivers to install i can't seem to figure it out.
                      Solution
                      A replacement driver for ELM327 1.2a under vista and windows can be found there:
                      http://www.prolific.com.tw
                      Download >> USB and Firewire >> USB to I/O Port Controllers >> PL-2303 Software and Drivers
                      Good luck
                        Mine uses a virtual COM-port, and as far as I remember, they all do..\
                        Try these: http://www.ftdichip.com/Drivers/VCP.htm
                        Most virtual COM-port devices use the FTDI chip.
