Any OBDII harnesses available that read in real time?
  • Any OBDII harnesses available that read in real time?
    Im running Digimoto 3.xx and i like the use of the On Screen Gauges. The only thing is, there is a delay. I am assuming it is the delay of the harness I am using (Elmscan). Is there anything better/faster out there that can display these gauges in real time?
    thanks
    Digimoto sells the mOByDic based interfaces now (we used to sell ELM), but the response speeds on this interface are much greater then what the ELM based interfaces can offer (albeit somewhat pricier).
    Joel Konecny
    Digimoto OBDII Diagnostics
      Delay can be introduced by a few things.
      Firstly, there can be standard delay anyway when doing queries and getting responses. Query messages as I understand it have lower priority than real-time traffic.
      There's also a delay in the 'ECU' converting your query by PID into something it can use by means of a lookup table. A Query by 'Offset' if that makes sense may speed this part up.
      But other than that there is some serialization delay introduced by putting the information across the 9600bps or 38400bps serial that the ELM units support. To address this you'd need to go to something quicker, like a CANUSB or a Drewtech Mongoose.
      Lukeyson
        Standards Request
        This is an extremely obtuse and nefarious question.
        But would someone have access to some standards that might be willing to PM me?
        I'm interested in:
        ISO15037-7 (aka SAE J2186)
        ISO9141-2
        ISO14229-1
        ISO11898 (any/all)
        I would be very grateful.
        Lukeyson
