Direction needed
  • Direction needed
    Hi, I am a newb here and need some help. I would like to install a engine monitoring system and not sure what I should be looking for. I have a Fujitsu Tablet that I will be using for GPS, that has W2K, 80 GB HD and 192 of RAM. I have a non OBll car, 8 cylinder, fuel injected with a Motronic DME. It seems to me that I need something to collect the data and convert it into a form that a software program would understand and display. I would also like to get the fault codes from the DME. I should also metion that in addition to the DME, the car has a additional brain that manages the engine.
    Any help would be greatly appreciated,
    Terry
    Is thier any help out there?
      Start by looking at the protocol required to access the diagnostics from your DME / car "brain", then the hardware required to interface to that. It may already be available "off the shelf".
      Sinclair
      http://www.kbmsystems.net
      http://www.obdkey.com
