ElmScan front end support???
  • ElmScan front end support???
    So I'm still new to carputing and I'm doing some research on OBD-II interfaces. I'm looking at buying the ElmScan ISO USB OBD-II connectorfor my Honda because it seems to be a reasonable price:
    (http://www.scantool.net/products/pro...products_id=41)
    Are there any good open source/freeware front ends that support this? Do any of the higher end front ends support this? I can only do very basic software tweaking.
    If this question belongs somewhere in the software/front end forums, feel free to move it (mods).
    http://www.mp3car.com/vbulletin/revi...treetdeck.html
    Maybe you will get some good info out of it.
    Jan Bennett
      hmm, I was hoping to avoid the $200 answer. Oh well, I still have lots of time to think about it.
        If you're going to be purchasing products (such as the ElmScan, etc.), there is a coupon with $300 in purchases right now.
        Jan Bennett
          I'd suggest you look into the OBDPro interface.
          http://www.obdpros.com/products_new.php
          That will do more than just ISO. It's ELM 327 compatible so you'll find some freebie software packages out there. It's less than the Scantool solution. If that StreetDeck works with the ELM based unit, it should be fine with this.
          I'm not sure what programming you can do, but here's a little sample app that I wrote for the OBDPro interface.
          http://www.mp3car.com/vbulletin/engi...plication.html
          Also, Paul from OBDPro is great with support. A big plus.
          2006 Nissan Maxima SE
          2002 GMC Envoy SLT
          Digital Deviation
            Hmmm..... I'm a little confused why I would pay $40 more for OBDpro over the ElmScan tool? They both look like decent products with decent software, but I only need ISO9141. Is the OBDpro software integrateable (word?) into one of the free/open source front ends?
            At the moment I'm pretty useless with programming even though I'm taking an advanced C++ course next semester.
              The OBDPro supports multiple protocols. So you could use it with Ford, GM, Honda, etc..
              The OBDPro is ELM 327 compatible. So if an app is written for the ELM, it should work with the OBDPro interface.
              Hopefully the class isn't too advanced. lol
              2002 GMC Envoy SLT
              Digital Deviation
                Addict: Thanks for the vote of confidence.
                Goldenley: I guess it really boils down to wether you would be switching cars in the near future, almost any new car will support CAN so the ISO interface will no longer work so you will end up having to spend more money to get a interface that works with CAN, but I agree if all you need is ISO then the ELMScan ISO is a good deal as you can save some money, but for an apples to apples price comparision you need to compare the ELMScan 327 vs the OBDPro since the OBDPro version is almost $ 50 cheaper than the ELMScan 327.
                Paul
                www.obdpros.com
                  If you want a smaller unit weighing only 40 grammes, have a look at OBDKey.
                    so what exactly is the full functionality of this
                    if its just to pull info then what can it pull that isn't already on the dash?
                    anything more helpful?
                    i do like knowing what can go on under the hood but i would like to be able to unlock the full potential of some of my bolt on mods too
                      try reading the thread that I linked to. It will show you more about what it shows.
                      And it pulls WAYYYYY more than what is shown on your dash. I'd suggest you do a bit more reading about exactly what OBD-II is before you go much further.
                      Jan Bennett
