Citroen xsara HDI OBD11 not connecting
  • Citroen xsara HDI OBD11 not connecting
    Hello
    New to the forum, had a good read through and looks like a great place my problem is I have elm327 interface when tried to read the fault on my Citroen xsara 110 hdi diesel all I see on the screen is not connected had tried it with several different type of software I am getting the same every time any help will be appreciated
    Stamps
    Hi,
    Can you tell me the age of your Xsara?
    It is likely that it is not OBD2/EOBD compliant I'm afraid. Diesel EU cars were not required to be compliant until 2004.
    Gareth
    UKOBD
      Hi Gareth
      Thanks for the quick reply the Citroen is 2002 about three months ago I had it diagnosed by a local garage the mechanic found couple of faults he reset the ECU he was using something similar to ELM interface that is why I bought my from the eBay asked the seller whether he could help in this matter not much help was forthcoming from him my PC recognizes the interface it goes through the routine of looking for my ECU and you can see all the lights flashing on the interface but will not connect asked the mechanic at the garage which interface did he use the wants to keep it a secret I don't blame him it is his living
      Stamps
        Best bet is to use some of the HyperTerminal commands to interogate the ECU and see if it reports that it is OBD2/EOBD compliant.
        Have a look on the Elm Electronics web-site for details of the commands that the chip accepts.
        Gareth
