Where can I find the OBD-II port in Mitsubishi Pajero ?
  • Where can I find the OBD-II port in Mitsubishi Pajero ?
    Shay
    thread moved to the OBD-II forum...since it's an OBD-II question...
    Jan Bennett
      Depending on the vehicle age it is under the dash in the driver's footwell, usually on a bracket above the brake pedal, near the steering column
