Suggest for me some OBD-II hardware.
  • Suggest for me some OBD-II hardware.
    I can probably write the software if I can find a driver somewhere for Java or .NET but what do I need in terms of hardware to plug it into my laptop? OBD-Serial adapter and then a serial-serial cable? That it? What's the cost on the adapter for a reliable but basic one? At first I want to be able to read but I might eventually want to get into adjusting things.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Our hardware www.obdpros.com will allow you to send any bus message to the vehicle and read the responses.
    Paul
      The one Paul linked is a custom chip that allows you to plug into the serial port of your laptop (or usb), and send ascii commands over the serial line to get responces according to either the OBDII pid list, or ELM-style commands. I've not yet come across an ELM327 command it does not support. I bought one and I recommend it.
      RevFE
      My Shop
