CAN data capture
  • CAN data capture
    I'm looking to use an OBD 2 interface to capture and analyse CAN data, is there anyone with software to capture data from a device - like the kvaser leaf light with the OBD2.
    (Oh does anyone know if the vauxhall corsa C (Z12XEP) uses CAN?)
    cheers.
    Corsa-C still uses the old trusted K-line and it complies to the EOBD standard.
    OBD2 is only used in the USA and not in Europe.
      CAN is used on european cars! My fiat stilo has it (2003 - 03reg) and my old punto hgt also used it (2000 W). It cannot be used for diagnostics but is used for windows, boot, clock, mpg information.
      I use an ELM327 v1.3 to log the data on my cars CAN bus (11bit/50k). Its very easy to use, just capture the logs to text files and look over the data in excel or something.
      Dan
