OBDII ELM Scan 327 to usb Centrafuse
  • OBDII ELM Scan 327 to usb Centrafuse
    I have an Acer aspire one running xp home, with centrafuse 2.0 installed, I have the obdii elmscan 327 installed with the supplied drivers, and i cannot get centrafuse to recognize the obdii, i selected the appropriate comm port (comm port 1, which i set it to before installing centrafuse). Its at the default baud rate 9600. Im just not sure what to do to get it to work. Thanks for any and all assistance.
    I have also altered the baud rate to 38400, it seems to be a prevelant alteration that seems to work, but not in my scenario.
      If you had an ElmScan 5, you could use STNFinder to help you troubleshoot. You can use STNTerm to try to send commands to the interface. Both utilities are here:
      http://www.scantool.net/scantool/downloads/utilities/
      Vitaliy
      OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
      Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
      You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
        I did the setup and everything worked perfectly.
        I think the speed is 9600 baud
        mobo asrock K7S41gx- Amd atlon 1,2Ghz -512Mb ram- hd 2,5" 160Gb- lilliput 7" 619 touch-gps Holux- bluetooth digicomm palladio-usb park assist (RRPDC) -obdII elm327-hubusb trust
