Anyone have actually data?
  • Anyone have actually data?
    I'm looking for actually Data so that I can check my MPG equations.
    For example, I'm looking for:
    KPH, IAT, MAP, RPM, Displacement, VE, MPG (actual MPG)
    Where VE is the volumetric efficiency. (An estimate is fine)
    Thanks,
    Thanks,
    What's "actually Data"?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
      MPG RPM Speed MAF MAP IAT
      17 741 23.61 11.37 48 312
      8 1689 34.18 46.24 71 312
      18 1108 41 27.98 70 311
      10 1472 31.69 33.53 64 312
      20 1113 41 22.81 60 311
      3 2012 25.48 69.37 90 312
      7 1050 21.13 15.72 48 323
      9 1785 50.95 51.72 79 322
      13 1586 59.03 52.86 88 319
      21 1846 68.97 35.11 53 317
      19 1907 70.84 42 61 316
      16 1836 68.35 45.49 68 315
      14 1604 59.65 46.91 78 313
      19 1547 55.92 34.31 63 312
      15 1243 46.6 34.24 76 312
      4 1943 26.72 66.37 88 313
      18 1351 49.71 30.27 65 312
      5 1781 36.66 56.78 84 323
      16 1276 47.22 26.78 59 323
      12 1471 54.06 49.88 90 318
      8 1850 49.09 59.78 85 316
      22 1744 66.49 32 52 313
      17 1662 62.14 42.68 68 313
      13 1603 59.65 50.62 84 312
      14 1741 62.76 51.49 79 310
      21 1835 68.97 37.49 58 310
      15 1491 55.3 40.09 73 310
      8 1761 46.6 58.6 87 309
      18 1620 60.27 37.12 63 310
      Here is some data I gathered from a 2007 Chevy Tahoe with a 5.3L V8. Instant MPG was read off the dash and a snap shot was taken of the various PIDs then the data was entered into spreadsheet. Sorry, I cant give out the whole spreadsheet.
        Oh
        Speed is in MPH and IAT in K.
          Aberk,
          Thanks so much for the data.
          Were the measurements taken at constant RPM and no acceleration?
          Neither the MAF or MAP equations generate results that closely match the dash MPG.
          The Inst Dash MPG is probably smoothed with many samples, but if you were moving along at constant RPM, load and no acceleration, it should be correct.
          The MAF equation is the most simple MPG = KPH*7.107/MAF
          On average its mismatches the Dash value by 13.77% on the high side, and is 120% off for the 7th sample.
            Aberk,
            Yes, they were all taken at a constant speed and RPM as best as possible.
            Your numbers seem a bit father off than mine. Did you take all my speeds and convert them back to KPH?
