Diagnostics tool for Nokia Symbian
  • Diagnostics tool for Nokia Symbian
    Almost ready with DTC codes (shows in hex at the moment)
    http://apps.sourceforge.net/trac/symbtelm
    or if you have "Need for Speed"
    http://www.racechrono.com
    EDIT:
    I received info that the tool was interesting, but wasn't telling enough.
    OK: the tool works on a Symbian Nokia Telephone and connects to a Bluetooth ELM OBD-II device.
    - it will then allow one to diagnose problems when it is finished.
    Displays more than just hex now
    Read more @ http://apps.sourceforge.net/trac/symbtelm/
    Owen Brotherwood, Denmark
    http://apps.sourceforge.net/trac/sym...WindowsVersion shows a screen shot of SymBtElm running on windows
    - at some stage I will write in serial support so it can also communicate with an ELM
      Will this work with the Elmscan 5?
      http://www.carplugs.com/obd2bluetooth.html
        Probably:
        - if the bluetooth can be connected to by your Nokia
        - and Elmscan 5 supports your car
        - and if the Elmscan used an original ELM 327 chip
        My program does not require a specific manuafacturer of an "ELM" device that uses an ELM 327 chip.
        This is the last time I answer this sort of question.
        My main hardware support is for:
        in german http://www.obd-2.de/eShop/index.php?...roducts_id=185
        in english http://www.obd-2.de/eShop/index.php?...85&language=en
        as I have one and activly fix bugs if it doesn't work.
        Any other device: ask the supplier.
          Thanks for that. I'l go for the hardware you link to, it's cheaper too!
          I have version 1.0.38 installed and working on my Nokia N78. That already has Python 1.04 instaled on it. When I tried to install later versions of Python I get a "Cannot instal, component is built in" error.
          Anything I can do to support development I wil.
            My wife just got an N86 8M so I will see if I can install on N series
            - I usually have E series
            I seem to remember you have to deinstall old versions of python when going from "old" python to new ...
            If you are a windows user, go for the windows setup file
            https://garage.maemo.org/frs/?group_...elease_id=2763
              Ah, just spotted the "uninstall old versions of Python" stuff. Will try tomorrow. What's the latest and best version to install on Symbian V60 3?
                I'm afraid I have to report, after tryng every version of Python from 1.9.0 onwards that they all throw up the same error on my Nokia N78, "Unable to install, component built-in."
                The only version of Python I have found that works is 1.04 with SysBTElm V1.0.38
                  Will it work with ElmCanII-WLAN?
                  I see that you definitely support the ECII-BT-INT (ElmCanII Bluetooth Intern).. which is nice.. but I find myself desiring the WLAN version so that the iPhone app "Rev " will also work... So, is there any chance that symbtelm will work with the ElmCanII-WLAN device? Either now or sometime in the not-too-distant future?
                    Another Symbian OBD-II
                    http://obdscope.urli.net/
                    - works for me and does what I need
