Centrafuse and cheap ODB-II cable
  • Centrafuse and cheap ODB-II cable
    I have a cheap ODB-II USB cable (got it from ebay)
    The VAG-COM software works fine, and it passes the VAG-COM ODB-II test function.
    How do I make the cable work with Centrafuse?
    In VAG-COM I just point to the right port, but in Centrafuse I have to choose some ELMxxxx setting?
    doesnt work with elm
    tried it many times
      CF has an obdII plugin iirc, but it is very simple. I was writing a elm compatable gauge plugin but there was nil interest so I abandoned it when my trial ran out. You might try asking in the cf forums. Maybe someone else wrote another one
      RevFE
      My Shop
        Ok, I have orderet a ELM327 based cable instead.
