Elmscan 5 USB Question
  • Elmscan 5 USB Question
    Does anyone know if leaving the Elmscan 5 cable plugged into the car while the car is off will kill my battery? I have noticed that when I have it plugged in and turn the car off the power light still stays on. I just want to make sure I don't leave it plugged in and end up with a dead battery in the morning!
    Thank you,
    Bill
    Well, I have one plugged in all the time ...
    - but I start the car every day.
    I have read that people do have them connected all the time.
    Owen Brotherwood, Denmark
    http://apps.sourceforge.net/trac/symbtelm/
      It seems like when the Elmscan isn't in use it uses very little power. It seems like the only thing on is the light. I haven't done a test to see how much power it actually uses, but I think you'll be fine.
      My Nearly Complete Car:
      http://www.mp3car.com/vbulletin/show...ed-car-pc.html
      Micro Control Center... Control Your Car Across the Internet
      http://www.mp3car.com/fusion-brain/1...-internet.html
      Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
      http://paulfurtado.com/
        And as a comment: if the ELM device is bluetooth, it can be it is discoverable also without the ignition off.
        I'll be investigating this latter
          Thank you guys I will try it and see what happens!
            I do not use the Elmscan, use HPTuners for scanning/logging/tuning - had a problem where if the device was plugged in and the car was not run for around 3 days the battery would be dead.......... added a relay to switch the OBD2 power line off if the ignition is off and all is well
            If anyone gives me a rev - I give them the Bird
