Dash Command on F-650 Ford
  • Dash Command on F-650 Ford
    I have the J1939 connecter ( supposedly ) and would like to know the possibility of installing any type of OBD-II scanner on the truck to use dash command
    Are you sure it's the J1939 connector? Can you post a picture? The last F-650 I saw (model year 2006 I think - it had the Cat engine) had a regular looking OBD-II style 16-pin connector. Unfortunately, I did not have my laptop with me at the time, so I have no idea what OBD-II protocol it supported (if any).
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
      this is the connecter and its 2008 model
      I really would like to have some sort of info on the carputer
        Yup, that's a J1939 connector. Can you pop the dust cover?
        Sadly, J1939 is fundamentally incompatible with OBDII. Hardware is the same (CAN), but the way messages are encoded and the way communication is structured, are completely different.
        Vitaliy
        OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
        Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
        You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
          There are some low cost J1939 solutions available PM me and I can send you the info
          You could also look at Autotap but they are expensive!
          Paul
          OBDPros Scantool
            I have encountered connectors like this in some heavy duty Chevy trucks that are actually J1708 in a J1962 connector. That took awhile to figure out.
              That's odd. Do they at least use the same CAN pins (6 & 14)?
              Vitaliy
                Vitaliy
                J1708 isn't CAN, but they used the J1850 pins. Which, ironically, are the same pins that are driven by our product for J1708. I.E. our device can be configured for heavyduty or OBDII and the same pins on our cable are used for J1708 and J1850, so all we did was change the connector and it all worked.
                  Sorry, I was thinking "J1939".
                    Are they still using the J1708 based diamond logic toolset for diagnostic and service?
                    F.N.
                      Not to resurrect an old thread but just in case anyone looks into this in the future...
                      Ford's service site (www.motorcraftservice.com) sells online access to the full Workshop Manual for their vehicles. I believe it's $20 for 1 month full access for one particular make/model/year. The manual gives information on the connector as well as pinout, protocols used, etc.
