Just released: OBDLink 1.1.3 update
  • Just released: OBDLink 1.1.3 update
    Click here to download the update.
    v1.1.3 - 2009/12/16
    - NEW: Added STIP1X command (set ISO P1Max timing)
    - NEW: Added STIP4 command (set ISO P4 timing)
    - NEW: Added STIAT command (turn ISO adaptive interbyte timing on/off)
    - CHG: In KWP2000 protocol with manual checksum mode on, the minimum data length for transmitted messages is now 2 bytes
    - CHG: ISO9141-2 messages are now truncated to 11 bytes or split into 11-byte chunks (maximum length for OBD-II messages) for normal reception (ATNL mode). This improves reliability of communication with 9494 keyword ECUs
    - CHG: When monitoring messages in ATNL mode while a KWP2000 protocol is selected, ISO9141-2 (CARB) messages are now truncated to 12 bytes or split into 12-byte chunks
    - BUG: During monitoring, first byte of ISO messages was sometimes printed incorrectly
    - BUG: J1850 PWM transmitter was reading J1850 VPW Rx input during bus acquisition
    - BUG: For UART baud rates below 611 baud, the divisor was calculated incorrectly
    - BUG: Under some rare circumstances, false feedback errors were detected during ISO 5-baud init
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
