OBDLink CI v1.3.0 is available
  • OBDLink CI v1.3.0 is available
    This is an official announcement for the v1.3.0 firmware update for OBDLink. You can download it from the following link:
    http://www.scantool.net/scantool/dow...k_ci-1.3.0.zip
    v1.3.0 - 2010/01/20
    - NEW: Added STMFR command (print device manufacturer ID string)
    - NEW: Added STDI command (print device hardware ID string)
    - NEW: Added STSN command (print device serial number)
    - NEW: Added [email protected] command (set [email protected] device description string)
    - CHG: STI command now prints controller ID, instead of device name
    - CHG: Implemented new [email protected] functionality (now changeable via [email protected])
    - CHG: Changed default programmable parameter 13 setting to 0xF4 (999ms)
    - BUG: Sometimes, 4 dots would be printed during ISO 5-baud init
    - BUG: Due to a compiler bug, under certain conditions, ISO keep-alives were sent back-to-back and tester address set via PP 06, was not used for keep-alive headers
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
