what is Hilux OBD protocol? kwp2000? or others?
  • what is Hilux OBD protocol? kwp2000? or others?
    Anybody can tell which protocol Hilux(toyota) support, It is KWP2000, ISO9141, or others? will Hilux support J1979.
    Thanks for your answer.
    It all depends on the model year, the type of fuel (petrol, diesel) and which part of the world you live in (Usa, Europe, Japan or the rest of the world).
    Does the car have the required 16-pin connector? Which pins are in this connector?
      Even that is no guarantee. In Japan, the connector will often be there, but it runs a tweaked version of the protocol and you need some weird unlock codes to get the module's to respond.
      In the EU it will generally be either ISO 9141 or CAN, depending on model year and fuel type. In North America, I'm not sure. The 'Tacoma' generally follows the US regulatory requirements, but I'm not sure about units built/sold as a 'Hilux'.
      -jjf
        it is have a 16 PIN connector
        Thanks for your reply.
        The vehicle have a 16 PIN connector. PIN 4,5,7,9,12,13,15,16 is available.
        Which protocol would this model use?
          Pins suggest ISO9141-2 or KWP2000. Whether or not the ecu actually supports the protocol depends on the rest of the question. Model year, fuel type, location.
            I'd bet that 7/15 are electrically K and L lines, but with 9, 12, and 13 stuffed, I'd generally expect J1979 *not* to be supported unless there is a regulatory requirement.
            -jjf
