OBD-II conector for Peugeot Partner-2 2003
  • OBD-II conector for Peugeot Partner-2 2003
    Hi,
    I got Peugeot Partner-2 2003 and i want to connect the OBD-II Com-Port to my computer.
    I Need to know what kind of protocol it's using ???
    In Ebay i saw the AUTO SCANNER SCAN TOOL CAN BUS OBDII OBD2 OBD-2-II EOBD and i want to know if it will fit to my car???
    Thenks ,
    Roi.
    Hi
    It depends on which you live and what is your engine? Diesel, Gazoline?
    Give us more infos
    www.outilsobdfacile.com
      I am having a 2003 Pegeuot Partner - 2 Diesel Engine ...
      The computer unit at the vehicle powered by Philips...
      What kind of info i need to give you more???
      Thanks,
      Roi.
        Not EOBD (Europe's version of OBD2) compliant. Doesn't have to be untill 2006 because it's a commercial vehicle. I know 2005 versions of the Partner still do not communicate with EOBD/OBD2 code readers.
