Vauxhall canbus controls
  • Vauxhall canbus controls
    Hi,
    i have a elm327 and i was just wondering if i could listen out for steering wheel control commands using the standard OBD2 port.
    im not sure if the steering wheel controls are on a seportate bus or not?
    can somebody point me in the right direction
    regards,
    Mark
    Steering wheel controls are on another can-bus, not on the powertrain one (pin 6&14) your elm connects to. It has a different speed also.
      hi, thanks for the info. so what would i need?
      i have been looking at this guys web site. its quite interesting.
      http://www.honeysw.com/canproject.php
      does anyone have any info on the PIDs for my cars steering wheel controls.
      its a Vauxhall Corsa C.
      Cheers,
      Mark
        I don't know if Vauxhall uses the GMLAN protocol. If it does, you may want to look at this project, since they managed to control the stereo and required only changing a single pin and shorting 2 others:
        http://gtosoft.webs.com/comingsoon.htm
        I am trying to do something for my Mitsubishi Outlander CarPC...I will give it a try!
          Ok so i think i minght have to buy these.
          http://comsol.secured-area.co.uk/aca...nterfaces.html
          http://www.coolcomponents.co.uk/cata...roducts_id=464
          the CAN232 also comes as a board. it would be nice if the firefly also came as a board.
          i carnt be the only person with CAN steering wheel controls/ displays thats got a car pc.
          it would be nice to bulk buy these!
            Cool ill take a look thanks alot! no idea but since vx is gm its quite likely
