Centrafuse wont recognise OBD unit
  • Centrafuse wont recognise OBD unit
    Hi all i have a ob unit from http://www.cartft.com/catalog/il/1018
    i cant seem to make it work i downloaded
    OBD-DIAG
    and all i keep getting is Comport not found
    Help lol
    Andrew
    What version of centrafuse your using...
    if its 3.0/3.1 you need to go into centrafuse settings and you look for the OBD2 settings they show up instead look for an option that says (advanced options) or (advanced settings) click on it and then if you look you will see the OBD2 option. go into it and then you can pic the the correct port.....
    hope this helps
