A 2003 Toyota Corolla OBD-II compliant?
  • A 2003 Toyota Corolla OBD-II compliant?
    Thx
    EMERSON VIER
    Depends on which part of the world you live and if the engine is diesel or petrol.
    It will be OBD2 compliant in the USA. It will be EOBD compliant if it has a petrol engine in the European Community.
      I live in Brazil, the fuel is GAS, I found the connector is compliant to OBD, but I not have more informantion about.
      Thx,
      Emerson Vier
        Doubt that it will be compliant with anything.
        Find somebody (professional or not) with a OBD2 scanner and give it a try.
          I check my connector an d the pins 4,5,7,9,12 and has connections, this help to check OBD-II compliant?
          If my car is not OBD-II compliant, what device I need found to read information and connect to Centrafuse?
          Thx
          EMERSON VIER
            check out:
            http://www.obdii.com/connector.html
            that explains a bit about whether or not your car is OBD-II compliant, however i'd advise you to search the web a bit about OBD-II in brazil. hope i helped
            birthdays are good for you. statistics show that the people who have the most live the longest.
              Some Cars have OBD-II female connectors but are not OBD-II compliant.
              It's rare but not impossible.
                Brazilian form of OBD is required from 2008 on. So, I doubt if this car complies to anything.
                Seems pin 16 in the diagnostic connector is missing, which is 12 volt power for the scanner.
                  I wouldn't say it's "rare". Most pre-MY2001 cars in Europe have the J1962 style DLC, even though the majority of them are not EOBD compliant.
                  Vitaliy
                  OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
                  Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
                  You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
                    I test my device
                    I use the software STNTERM and again not work...
                    ATZ
                    ATZ
                    ELM327 v1.3a
                    >ATH1
                    ATH1
                    OK
                    >ATSP00
                    ATSP00
                    OK
                    >0100
                    0100
                    SEARCHING...
                    UNABLE TO CONNECT
                    >ATZ
                    ATZ
                    ELM327 v1.3a
                    >ATH1
                    ATH1
                    OK
                    >ATSP3
                    ATSP3
                    OK
                    >0100
                    0100
                    BUS INIT: ...ERROR
                    >011C
                    011C
                    BUS INIT: ...ERROR
                      So, not compliant.
                        Can I know what the device work on my car?
                        Emerson Vier
                          You will probably have to use some manufacturer specific tool... but good luck finding one, or even getting any information on it.
                          RevFE
                          My Shop
                            Launch and Carmanscan have very good Toyota coverage.
