Can't Clear Trouble Codes on VPW protocol?
  • Can't Clear Trouble Codes on VPW protocol?
    I'm able to read Pending and Trouble codes via VPW, but I can't seem to clear them.
    I send this packet:
    68, 6A, F1, 04, CRC
    The ECU responds with
    48, 6B, 10, 44, 52
    Clearly the ECU got the packet and it has responded....Seems all is well.
    But I if I then check the codes again, they are still there.
    Note that I removed the fault condition before attempting to clear the codes.
    Is this a case of a VPW ECM not supporting this function?
    I have tried it on a 1997 Saturn SL and on a 2003 PT cruiser..(Ya, weird that the Crysler uses VPW) Can't clear the codes on either.
    Looking closely at the Standard J1979, it actually says that "All ECUs shall respond to this request". But it does not actually say that it must carry out the clearing process.
    Thanks,
    Originally posted by split63 View Post
    I'm able to read Pending and Trouble codes via VPM, but I can't seem to clear them.
    I send this packet:
    68, 6A, F1, 04, CRC
    48, 6B, 10, 44, 52
    Thanks,
    Can you post responses to 0100, 0101, 011C, 03 and 07?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
      Here you go...
      48,6B,10,41,00,BE,3E,B8,10,E7
      48,6B,10,41,01,00,07,E1,E1,A3
      No response to 1C
      48,6B,10,43,01,22,00,00,00,00,E3 (TC=P0122)
      48,6B,10,47,01,22,00,00,00,00,8A (TC=P0122)
      and
      48,6B,10,44,52 (Clear Codes response)
      Thanks,
        Whenever a DTC is hard and present it always looks you can't clear the code.
        In fact you do clear it, but before you can read the codes the ecu has reset the code.
          I introduce the fault and power up the ECU. Then I remove the fault, read the codes, clear the code and then read the code again. But the codes remain.
          Also, from my limited testing, it appears that the ECU is only checking for the fault at power-up. If I introduce the fault after power up, no code is posted.
            So what do you think? Is there something wrong, or is this just how these older VPW ECUs operate?
