What diagnostics cable & software for BMW 2.5 TD 1995
  • What diagnostics cable & software for BMW 2.5 TD 1995
    Hello all
    I'm looking to buy a diagnostic device to plug into the 20 pin socket under the bonnet.
    There is no OBD1 / 2 socket in the car as it it PRE 1996.
    However I can buy an adapter - 16 pin OBD2 to 20 pin BMW.
    1) Which would allow me to connect the OBD2 end to a OBD2 handheld device.
    2) Alternatively I could connect the OBD2 cable end to a VAG com type cable with the USB on it, so I could plug the usb into a laptop & the 20 pin end into the BMW.
    VAG CABLE
    http://cgi.ebay.co.uk/409-1-KKL-VAG-...item4ceffec6f7
    BMW CABLE
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Or buy a kit as follows:
    BMW KIT
    I know the VAG com cable is for the volks/audi/seat groups, but if i linked it to the 20 pin bmw cable & had the right software I'm sure it would work.
    I presume its the diagnostic SOFTWARE on the disc that gets the cable working etc.
    I look forward to any replies.
    There's no 16-pin socket because the car is pre-2004.
    Diesels in Europe only had to comply to EOBD starting at 1st. January 2004.
    You'll need something like Carsoft for this one.
      I already know there's no 16 pin plug in the car as my opening thread post states.
      Please read the post properly.
        Unfortunately the ONLY thing that will work with 100% sertanty on your car is a CarSoft 6.5 (or newer) kit. This is the same tool BMW mechanincs use.
        For a long time CarSoft only used serial connection, and where quite pickey on the USB->Serial adapters.
        Carsoft: Home Edition
        http://www.carsoftinternational.com/...oft_bmwv73.htm
          Have you read my post? Especially the last word of the 1st sentence?
          Have you read the 3rd line? I know that's not what you want to hear, but that's how it is.
          You have had a similar answer on another forum. Now you can ask the question on 10 more forums, the answer is still the same.
          You need BMW-specific software. There's no cheap solution.
            ^^ As I said earlier... The only thing that will work for reading fault codes and resetting them is original software and equipment.
            Though. I do know of people that have been able to use "taiwan special" hardware, but the still needed to use CarSoft's software.
              Did somebody try revers protocol(s) on BMW ?
              Why there is no cheaper solution ? Is there some type of crypting ?
              Tomas
                What about BMW & MINI DIS (v57) SSS (v32) and BMW TIS (v8) someone suggested this would work or cover the car I want to use it on.
                I have heard of people buying the VAG cable (see pic in 1st post) then connecting it to the BMW cable (see pic 1st post) - so you have a USB connector one end & 20 pin socket the other.
                You connect the VAG OBDII cable male end to the BMW adaptor OBDII female socket.
                Basically you link the 2 cables together.
                Then via the above software DIS v57 or the carsoft 6.5 software you can access the car.
                  Yes, I reversed engineered the BMW protocols for several manufacturers of aftermarket scanners. But that is an entirely different price class - a lot more expensive than Carsoft.
                  You can buy Carsoft for a few hunderd euro. Professional aftermarket scanners are several thousand.
                    Easiest and most cost-effective route is the FCX3 (http://www.ukobd.co.uk/shop/12-bmw-t...rch-fcx-3.html) which plugs straight into the port.
                      Nice piece of equipment from Peake.
                      Except the manual has no listings for diesel fault codes.
                      Rather useless here I think.
                        Hi again p2psmurf,
                        Maybe you are looking at the US version of the manual?
                        The European version listed the diesel fault codes
                          hello,
                          ok.. i know im a bit late, but have just started gettin in2 this as Im lookin to fit my car out.. and im lookin at this obd ii stuff...
                          so im from australia,, have a 97 323 with no obd plug under the dash..
                          how ever.. i have the 20pin round plug under the bonnet.. I work at a car yard and we have a snap on computer that cost about 18grand for diagnosing many MANY cars.. when I connect this computer 2 my car using the round 20 pin connector.. i gives me information like the following....
                          coolant temp
                          oil temp
                          oil pressure
                          throttle position
                          co2 intake
                          etc etc
                          so.. i would have 2 say something like http://www.mo-co-so.com/ProductDetai...A-LNK&CartID=5 with the adapter plug will work.. i see no reason why it would not work.
                            Gary, the reason it doesn't work is because the communication method used by the interface is not supported by the ecu. Not on your '97 323 ans most certainly not by a 1995 diesel. It's not required by law, so BMW didn't add the support.
                            Look at this way: the car's engine ecu only speaks German and the OBD2 interface is asking questions in English. You won't get an answer that way.
                            Your Snap-on talks German to your car, that's why you can see the data.
                              the Underdog BMW-Software
                              The Underdog BMW-Software is EasyCarCom.
