Need Help - Features Of My Car's OBD
  • Need Help - Features Of My Car's OBD
    I am trying to figure out what features i can use OBD II in my neon, will i be able to get all features Centrafuse or Scantool uses such as
    Intake Air Temperature
    Engine Load
    Fuel Pressure
    Air Flow Rate
    Intake Manifold Pressure
    Etc?
    A few of these showed as N/A what does that mean?
    On/Off Switch For OBD II
    Next question i did some modifications and was wondering if there is a way to turn the OBD II hardware off and on with out unplugging because of the wire length. The device will be hidden under my Center Console...Good or Bad Idea?
      N/A means Not Available.
      The only way you can switch off the hardware without unplugging is adding a switch to the 12 volt feed on pin 16.
        Ok should i add that switch on the car side or the OBD wire hardware side?
          Whatever is easier to fit I think.
