Obdkey hscan
  • Obdkey hscan
    I 'm using OBDKey How can I access the High Speed bus ? Is medium speed default?
    OBDKey
    You mean you want to monitor the CAN bus? Or access the engine controller (ECU) OBD-II for diagnostics?
    To access diagnostics, you can send the commands:
    ATZ
    ATSP0
    0100
    Then
    ATDP will show which OBD-II protocol is in use (make sure key in, engine off (dash lights on)/ engine on)
    Let me know if you're doing anything more advanced than this?
