Ford Fiesta (UK) 2010 VIN
  • Ford Fiesta (UK) 2010 VIN
    Hi All,
    I am experiencing some difficulty in reading VIN out of my ford fiesta 2010(UK model). I am sending mode 9 pid 0 to check if the VIN is supported. It comes back with 54 that means it does support VIN.
    Tx - 02 09 00 00 00 00 00 00
    Rx - 06 49 00 54 00 00 00 AA
    Now when I send mode 9 pid 2 to read VIN it comes with following response:
    Tx - 02 09 02 00 00 00 00 00
    Rx - 10 14 49 02 01 FF FF FF
    When I send flow control frame it comes with the following response:
    Tx - 03 00 00 00 00 00 00 00
    Rx - 21 FF FF FF FF FF FF FF
    Rx - 22 FF FF FF FF FF FF FF
    So instead of gettting actual VIN I get all FFs.
    Does anyone know what is going on?
    I read it on wikipedia that 0902 comes back with 5 messages containing VIN chars as ascii. But dont know if I have to do that way?
    P.S. Reading PIDs is working perfectly fine...!!!!
    Any help is greatly appreciated.
    Cheers,
    Nirav
    CAN VIN Read
    It may be your ECU has not been coded correctly?
    I have a trace using the OBDKey Bluetooth vehicle interface from a Mazda RX8 using CAN bus which gives:
    Rx - 10 14 49 02 01 4A 4D 5A
    Tx - Flow control
    Rx - 21 53 45 31 37 33 36 30
    Rx - 22 30 31 31 38 34 3x 3x (last two numbers obscured by me)
    This decodes to JMZSE1736001184xx
      Tx - Flow control
      Hi sinclairvital,
      Thanks for the reply. So are you saying I will never be able to read VIN of my fiesta? Is there a way we can confirm that ECU is not coded correctly?
      Thanx,
      Nirav
        Originally posted by nambaliya View Post
        Hi sinclairvital,
        Thanx,
        Nirav
        What year is your Fiesta? Is it a standard production vehicle? Ever had the ECU remapped / updated? Do you have it serviced by Ford?
        Sinclair
          Sinclair
          Well its a brand new standard production vehicle. Never had the ECU remapped / updated. As its new, never been serviced.
          Thnx,
          Nirav
