'06 Ford Focus CAN Data Errors on ELM327 1.2a
  • '06 Ford Focus CAN Data Errors on ELM327 1.2a
    I'm getting "DATA ERROR" while listing all received CAN Traffic on my '06 Focus using a (probably generic knock-off?) ELM327 1.2a. Is my ELM so out of date that it's not understanding the data from these certain modules on the network? This is after changing my baud-rate to 115200, so the buffer didn't fill up quite so quickly, turning on headers, and running the AT MA command.
    231 00 <DATA ERROR
    3E9 00 <DATA ERROR
    4B0 27 10 27 10 27 10 27 10
    200 27 61 26 F7 27 60 80 00
    205 00 <DATA ERROR
    231 00 <DATA ERROR
    250 00 <DATA ERROR
    205 00 <DATA ERROR
    231 00 <DATA ERROR
    3E9 00 <DATA ERROR
    205 00 <DATA ERROR
    231 00 <DATA ERROR
    433 00 <DATA ERROR
    205 00 <DATA ERROR
    231 00 <DATA ERROR
    4B0 & 200 are the only two modules I can ever seem to get any data from. Can someone shed some light on my obvious misunderstanding about how this is supposed to work?
    Also, anyone know any sources for on-going reverse engineering of CAN data from these vehicles? I'm just getting into it, wondering if there was any place besides the bottom to start from.
    Thanks!
    Dave
    ELM327 expects the DCL to always equal 8, hence the error. Newer versions (IIRC, v1.3 and above) don't have this problem.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
      Hi,
      I do the same experiment than dmcglynn and I've got some "Data error" (with a 1.4 version)
      Code:
      201 11 B9 7B 58 27 10 00 7D
      230 00 01 66 00 64 00 0F 80
      360 00 00 00 00 00 00 00 99
      080 27 10 75 30 01 30 24
      090 47 08 57 08 07 F7 17 D0 <DATA ERROR
      210 FF FE 3C A4 40 00 24 <DATA ERROR
      ELM327 datasheet talk about CAN auto formating with expect ISO 15765 CAN message, but I'm sure to understand.
      Somebody has an idea? Thanks
      www.outilsobdfacile.com
        Can you guys turn on display of the DLC? "AT D1"
        remus08, I think your problem may be unrelated. Notice how dcmglynn's <DATA ERRORs follow only the short frames. <DATA ERROR in that position may point to an actual CRC mismatch.
        Vitaliy
          Thanks for the response.
          DLC commands, both "AT D1" & "AT V1" are apparently unsupported on the version 1.2a ELM327 that I have. Both just return the familiar "shoulder-shrug" response of "?".
          Thanks for the info though.
          Dave
            Right my problem is not the same. I didn't notice that actually I use my interface @230400 baud and it's a 1.3a version.
            I will try to enable DLC, disable CAN auto formatting and make another measurment
              Hi,
              Ok, I've done the test again
              This time, I've disabled CAN automatic formatting (command AT CAF) and enable DLC option
              Code:
              362.319922 > ATCAF0
              362.340576 < OK
              362.340611 <
              362.340634 < >
              371.825821 > ATD1
              371.857177 < OK
              371.857211 <
              371.857233 < >
              394.824137 > ATMA
              395.109342 < 43078A005746800000
              395.110296 < 200701E701E801E810
              395.110475 < 20181BA87DC53D74007C
              395.110651 < 23080500570064000080
              395.111521 < 3608000000000008002F
              395.113160 < 0807266B74BC0133AC
              395.113340 < 0908C6CFD6E907451795
              395.113504 < 2107FFFE3CA44000AC
              395.114220 < 4B083D893D603D7D3D4E
              395.114386 < 200701E801E801E810
              395.114565 < 23080500570064000080
              395.115299 < 3608000000000008002F
              As you can see, everything woks well, so think to disable CAF option
              PS: Now, I'm looking for to understand the data, if someone has some clue, that would be great!!
                No clue, except that the first three nibbles are the 11-bit CAN ID, and the fourth nibble is the DLC.
                I would approach the problem thus:
                1. Make a list of all IDs that you see.
                2. Set up the filters to receive one ID at a time.
                3. Tweak things (open/close doors, turn switches on/off, vary RPM, etc), and see if the data changes.
                Best regards,
                Vitaliy
